997 ipod & Bluetooth product
Old May 16, 2010 | 05:15 PM
Kafka997's Avatar
Kafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond repute
I just had a Mobridge Most Bluetooth & iPod product professionally installed in my 2007 TT. I am very impressed with how it works - it's as if it came with car only with the latest technology. Both work through steering wheel buttons if you have them (I don't).
The Bluetooth uses a small two headed microphone with background noise reducer mounted at the top of the windshield by the rear mirror - you can hardly see it and there are no visible wires. It works through you stereo-nav system just like an OEM product. It automatically links and updates your phone numbers each time you get in the car. It mutes the stereo or whatever if a call comes in and what I like is you can keep the sound system turn off and if you get a call it automatically turns in on to link you with the call. All info, such as phone book, missed calls, favorite numbers etc. are readily displayed on the stereo-nav screen. The only limitation I've found is that you can't voice dial. Call sound is extremely clear.
The iPod interface works as well and through the stereo-nav system. You can basically use it as if you are just using the iPod itself. It just turns on when you turn the ignition on and you're ready to play songs, play lists, search by album, artist, genre etc. Your single CD player still works as before. I had my iPod hook up put in my glove box but you can have it elsewhere. It also includes an extra male plug for hooking up non-iPod products.
I highly recommend this product. It was about $1500 professionally installed and another $150 to have the error code cleared (so it doesn't look for the stock default).
Anyone else tried this product? I'm almost tempted to upgrade the sound system but it's big bucks and adds a bit of weight - my exhaust is still my favorite sound.
K.
Old May 16, 2010 | 05:46 PM
handdoc's Avatar
handdoc is infamous around these parts
i was looking at the same thing, but i havent bit the bullet yet due to cost
Old May 16, 2010 | 06:11 PM
Kafka997's Avatar
You're right
You're right - it is a chunk of change!. I looked around at less expensive possibilities but they all lacked many of the options that make this product so easy to use and full of options. You get software upgrades for it about once or twice a year as well. I think it uses Parrot software.
I originally was going to do it in stages to save money but it actually costs quite a bit more to do it this way due to labor and what's involved with the complex wiring.
Hope you can swing it in the not too distant future.
K.
Old May 16, 2010 | 06:40 PM
PCJR's Avatar
PCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to behold
Will the factory CD changer still function with this setup?
I am considering something like what you described for my TT & Cayenne but both have cd changers in them.
TIA,
Pete
Old May 16, 2010 | 07:44 PM
Kafka997's Avatar
Nope
TIA,
Pete
No, the 6 CD changes needs to be disconnected but the one in dash CD player still works. The iPod functions looks like 6 CDs with each "CD" (CD 1,2, 3, etc.) having its own function (e.g. play list, albums, etc.) with various options within each of these including search, play, random, repeat, etc. So you can choose and play by album, song, play list, artist, and so on (I also listen bo audio books). If you have the iPod you won't need your CD changer. The manual gives great instructions and it's fairly easy to learn and you use various buttons on the audio system. While your CD changer is disconnected you still have it in place should want to hook it up again. Just set up your iPod as you like it through iTunes and your Ombridge will read it.
K.
P.S. Here is the web site with some general info (mine is MOST Bluetooth-iPod-Aux model). http://www.mobridgeinc.com/
Old May 16, 2010 | 10:20 PM
tranman329's Avatar
tranman329 is infamous around these parts
can you initiate phone calls from your phone and the BT will work? I have the denison and in order for my calls to work via BT, i have to initiate the call from the car system.
Old May 16, 2010 | 10:35 PM
Siglo Man's Avatar
Siglo Man is infamous around these partsSiglo Man is infamous around these parts
Just had it installed last week. Bluetooth works great but my only complaint is that the ipod cable is just that and does not work with my iphone. I have inquired if there is a newer system that works with an iphone since that is my ipod. I also had a iphone mount installed just to the right of the center console for use of my dynolicious app (which is amazing) which I would like to hardwire the mount to the cable to play my music when it is in the cradle
Old May 16, 2010 | 10:43 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Once you get an Ipod system in, your CD changer becomes useless weight.
Old May 17, 2010 | 06:00 AM
Kafka997's Avatar
yes
Interesting thought. I just tried and you can initiate calls from the phone itself that then run through the Ombrirdge. I'm impressed how it turns on the system to take a call if you have your stereo and nav turned off.
K.
Old May 17, 2010 | 06:04 AM
Kafka997's Avatar
Sort off
This is partially true since they removed the "guts" of the changer - the metal holder and changer which weighs about a pound - so I'm not sure what's left. They did offer to remove the whole changer unit but I left it in for future options.
K
Duane996TT - I see your from SD (lucky guy). I'm driving down next week from Canada to enjoy your part of the world for a few months. Hope there is no "June gloom"!
Old May 17, 2010 | 06:30 AM
W211's Avatar
W211 is infamous around these parts
Lightbulb
On my Dension Gateway 500 (iPod) paired with the NavTV Tooki, I can initiate calls from my BlackBerry and the car will pick up the call via bluetooth.
Old May 17, 2010 | 07:23 AM
ROB911TRB's Avatar
ROB911TRB is a glorious beacon of lightROB911TRB is a glorious beacon of lightROB911TRB is a glorious beacon of lightROB911TRB is a glorious beacon of lightROB911TRB is a glorious beacon of lightROB911TRB is a glorious beacon of light
I have the Dension equivalent (Bluetooth and iPod) installed in my 997TT and works great too, it integrates seamlessly with the PCM. Great product.
Old May 17, 2010 | 10:56 AM
cannga's Avatar
Question pls: Which cell phone do you use? i.e. This is a Dension "problem" or a cell phone problem??
Could those with Dension confirm that this is true for other brands of cell phone as well? TIA.
I was thinking about installing Dension, but if this is the case I'll go with something else.
Old May 17, 2010 | 11:45 AM
getz's Avatar
getz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud ofgetz has much to be proud of
I was trying to purchase a denison unit, but they are allegedly on back order until June. Grrrr..... Does this really not work with the iphone? I just want the ipod function, and could care less about the bluetooth.
-Getz
Old May 17, 2010 | 12:16 PM
cannga's Avatar
K
Why do they have to remove the changer (not sure that I like this idea)? I thought all they do is disable the changer electronically?
Could you please comment on the sound quality? A friend has Tooki and the sound quality is only ok when he calls me from his car. Thanks in advance.
