Does FVD flash raise rev limiter?
Old Jun 28, 2010 | 11:24 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Old Jun 29, 2010 | 08:38 AM
TT Surgeon's Avatar
yes, whenever you raise the RL, you will record type 1 and 2's everytime you go above 6750 RPMs. nothing to worry about.
Old Jun 29, 2010 | 10:03 AM
The Bogg's Avatar
Hmmmm...I was told by another tuner that when he raises the RL it also raises the threshold for recording overrevs by the same amount.
Old Jun 29, 2010 | 06:30 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
quote:
<table border="0" cellpadding="6" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border: 1px inset;"> originally posted by tt surgeon
yes, whenever you raise the rl, you will record type 1 and 2's everytime you go above 6750 rpms. Nothing to worry about.
</td> </tr> </tbody></table>
hmmmm...i was told by another tuner that when he raises the rl it also raises the threshold for recording overrevs by the same amount. <!-- google_ad_section_end --> <!-- / message --> <!-- controls -->
true !
Old Jun 30, 2010 | 07:57 AM
TT Surgeon's Avatar
Nope, to the ecu you are over-revving and tripping type 1 and 2's. Whether you achieve that by modifying the RL ceiling or missing a shift makes no diffference to the ecu. However, there is a way to side step it, but very difficult and probably of little value. I know the fvd/softronic style obd2 flashes for the most part trip 1 and 2s after raising the RL.
Old Jun 30, 2010 | 10:02 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Agreed. This is also true with Proto/softronic flashes as well.
Old Jun 30, 2010 | 09:46 PM
Abby997TT's Avatar
Thanks alot guys! What`s the rev limiter for the FVD flashed cars anyways?
Old Jul 1, 2010 | 05:37 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
7000rpm
Old Jul 1, 2010 | 01:37 PM
Abby997TT's Avatar
Thumbs up
Thanks!
Old Jul 2, 2010 | 10:02 PM
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
Just for some info the Softronic flashes can have the limiter raised or not. Now once it is raised it will index as the stock file does when the engine reaches the hard limiter. Basically if you floor the car and bounce of it it will index while driving. You would not gain in the over revs if you do not do this. As an example it could be raised to 9k in which is very high and it would not index unless you run into it at 9k. This would apply to any variable from stock and above.
Best,
Scott
Old Jul 3, 2010 | 01:13 AM
TTdude's Avatar
Best,
Scott
Can someone with a Softronic tune verify if this is actually the case? I was told a similar thing by Proto with my tune which uses the same Softronic/Durametric interface as Softronic and FVD. Unbeknownst to Proto, I discovered that there is a bug somewhere and the overres do in fact get recorded even when you don't bounce off the hard limiter. This also seems to be the case with FVD. I don't care about overrevs so it's no big deal to me but I'm wondering what does Softronic do that others seemingly cannot to avoid registering overrevs?
Old Jul 3, 2010 | 02:29 AM
Abby997TT's Avatar
TTdude,
Are you happy with the proto tune? How's the power compare to stock tune? Major difference?
Thanks!
Old Jul 3, 2010 | 02:30 AM
Abby997TT's Avatar
Scott,
Thanks for the information!
Old Jul 3, 2010 | 03:09 AM
tranman329's Avatar
tranman329 is infamous around these parts
I just got the proto tune recently as well.
Old Jul 3, 2010 | 10:07 AM
Abby997TT's Avatar
how do you like it?
