If PDK is so great.....
The problem is that you keep mixing in things that aren't totally relevant to the initial point. You also don't have an understanding of the gearboxes you are talking about so your points are garbled into gibberish.
All sequentials are not dual clutch, all paddle shifters are still not dual clutch, electronic dual clutches are not raced much except for a few low level sprint races like the GT-R's which left WC and I'm not sure if they have returned yet or not.
So the authority on which you speak is flawed because simply put all of the transmission you use to support your theory are still closer designs to the manuals and not the PDK/DSG. The only difference is the method of shifting. And that can easily be incorporated into a street car.
It doesn't take a rocket scientist to understand these gearboxes. Any 8 yr old who plays Gran Turismo knows about these transmissions. Please don't flatter yourself.
What exactly about my reporting that removing some of the "fun and excitement" is what some owners want for their drivers confuses you?
Perhaps I can better explain. If you are parsing useless crap and attempting to 'look' intelligent by pointing out the differences between a SINGLE CLUTCH sequential paddle shifter (as offered in the Lexus LF-A, E46 M3), and DUAL CLUTCH paddle shifter (as offered in the GT-R, E90 M3, PDK in Porsches, Bugattis, and SST in the Mitsu's, etc...), then safe your keystrokes - because it is completely irrelevant.
My point - paddle shifting transmissions are quicker - AT WHAT POINT DOES RACING BECOME MORE ABOUT FUN THAN TRACK TIME?
I said that these transmissions would be better suited on track (paraphrased from an earlier post), but a side benefit is easier daily driving capability.
let me show you (in case you forgot):
For some reason you added this:
The sequential gearbox in the Cup Cars is more like a Manual than a PDK. As long as Porsche are using motors that are homologated to racing, the manual gearbox will be mated to the motor as easily as the Sequential which means no additional R&D or cost.
PDK will always be more expensive. It costs more to make, has more parts and costs more to maintain. That will never change.
And this is Porsche we are talking about, it will be a long time before you have to special order a manual.
Let me know when you have something relevant to add, instead of attempting to condescend others based on your own trivial nonsense.
You're talking out of both sides of your mouth, and it's getting boring (I'll give you an example so you don't respond childishly: The "Name that transmission" comment that followed the "not all seq are..." statement).
Of course not all sequentials are paddle shift. Again, my 8 yr old knows this. Hell, my 4 yr old knows how to shift a sequential stick. Didn't they have these in the arcades back in the '80s? These aren't industry secrets man, and you're not the only one who knows about transmissions.
How does any of your ranting have ANY relevance to that exchange (that was already completed between the two understanding parties)?
I love how the new engine is considered inferior to the old one..
Why?
Because is sucks less gas?
Has 40 less parts?
Is generally more powerfull?
Or is it because you can't boost it to 2X the stock power level? Is that really how an engine should be judged? Has a new engine actually had a problem?
Is it because it does not have the same true dry sump? Is there a problem with the motor starving for oil?
The fact is that the new motor with the PDK is better than the system it replaces in stock form. It is so good in fact that you really don't need to do anything to it.
Like every car before it over time tuners will get more power out of it.
Why?
Has 40 less parts?
Why?
Has 40 less parts?
Why?
Has 40 less parts?
Porsche isn't known for it's regular motors, this is not Toyota. It's known for it's race motors which are on all of it's GT cars. For a street application I agree, the A91 is a better application. And being that, Porsche should easily be able to derive a forged reliable motor to handle FI applications.
However Porsche's history is so embedded in racing, you can't separate the motor from racing. Obviously Porsche can make a good V8 race engine like the one in the Spyder, however it is too be determined if this A91 design can compete at the highest levels.
And don't forget the top gear episode where the Prius got worse gas mileage than the M3 at full blast. When making performance engines, it's a completely different story, this isn't putting on the highway at 2k rpms.
The PDK Turbo is not a dry sump. It's an "integrated" dry sump .
The 07-09 Turbos are dry sump and would not be PDK compatible,
Are you suggesting the presence of a true dry sump lubrication system on earlier models is the reason why PDK would not be compatible?
And here I thought it was because the GT1 engine was too long for the PDK to fit. So much to learn, so little time left.
calexand
Nov 5, 2015 01:05 PM
Kalvin Chen
Oct 20, 2015 09:18 AM
Oct 6, 2015 06:13 PM
