Fuel light
Old Jan 9, 2011 | 09:44 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Fuel light
Approximately (or exactly) how much fuel is in the tank once the light turns on?
Old Jan 10, 2011 | 06:23 AM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
2.6 g (10 l)
Old Jan 10, 2011 | 06:42 AM
bonehead's Avatar
Originally Posted by drsullivan
2.6 g (10 l)
Thanks Shawn! Please don't tell me that info is in the owner's manual
Old Jan 10, 2011 | 06:50 AM
MBailey's Avatar
That is only true if you are still on stock injectors, which I think you are right?
Old Jan 10, 2011 | 07:53 AM
bonehead's Avatar
Correctamundo. Stock injectors.
Old Jan 10, 2011 | 08:58 AM
jhbrennan's Avatar
Page 94 or thereabouts.
Old Jan 10, 2011 | 09:00 AM
bonehead's Avatar
Well, just color me embarrassed
Old Jan 15, 2011 | 12:27 PM
bonehead's Avatar
Well, the light was on for a few miles. Didn't want to tempt fate and have the car die in the middle of the road. So, I filled her up with 91 just to see how much was left in the tank.
11.98 gallons WTF? 17.7 gal tank capacity. So there was close to 6 gallons (i.e. 1/3 of a tank) left in there. Boy, that light is VERY inaccurate.
Old Jan 15, 2011 | 12:49 PM
jhbrennan's Avatar
What did the gauge indicate when the light came on?
Old Jan 15, 2011 | 12:50 PM
bonehead's Avatar
Not sure I understand your question.
Old Jan 15, 2011 | 12:52 PM
jhbrennan's Avatar
Where was the needle pointing - E or 1/4 or somewhere else?
Old Jan 15, 2011 | 12:55 PM
bonehead's Avatar
Ah. Hovering right over/slightly above the light. I supposed if you consider that the light is where the 2nd tick should be, around 4-5 gallons in the tank would be about right. But where do they get 2.6 gal from??
Old Jan 15, 2011 | 07:05 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Thanks Ed for the useful info. I used to carry a 5 gal can of ms109 when I was driving down the tank of 91. Even when the needle bottomed out it kept going. It seemed like it could go forever. It's good to know how much is actually in there when the light comes on.
Old Jan 15, 2011 | 07:23 PM
bonehead's Avatar
Dave, even when the light goes off, my guess is there's probably a variability of anywhere from 2-4 gallons. The estimated range with the light on was about 48-50 miles. That certainly translates into a lot less than 6 gallons. Upshot is that the fuel light and/or range meter is pretty worthless
My hope was that it would be a bit more accurate for the purposes of mixing fuel. Although I'm tuned for 94, I'd like to aim for 96 as a safety net. With a 5 gallon pail, that translates into mixing in 9 gallons of 91. But without knowing how much is truly in the tank, I may just have to run it down as far as possible and add just the 109. Kind of a waste. Either that, or siphon out the remainder of the tank, add 109, and then hit the pump (inconvenient to say the least).
Old Jan 15, 2011 | 08:22 PM
TTdude's Avatar
Yeah, it's a guessing game unless you keep driving around your block until you run out of gas. Then your neighbors think your strange but they probably do already.
COBB Tuning
Mar 29, 2016 09:26 PM
J9277655
Dec 28, 2015 11:01 PM
Michael_s
Sep 11, 2015 08:03 PM
GSR Autosport
Aug 26, 2015 05:20 PM
