PCCB Brake Service Cost
Old Jan 20, 2011 | 03:06 PM
jasont's Avatar
jasont is infamous around these parts
For those of you who replaced you PCCB pads with OE equipment, what were you charged?
My 08 997tt is in for some warranty repairs and the dealer says the pads are still fine at 50%; however, I have seen it suggested on here many times that you should replace them at 50% to lengthen the rotor life.
They are quoting:
$1140 pads and labor for the front
$1200 pads and labor rear
Seems excessive to me - anyone find an aftermarket pads for the ceramic brakes you would recommend?
Old Jan 20, 2011 | 03:36 PM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
They are quoting:
suncoast is quoting $350 and $320 for the pads. what is your dealer charging just for the parts? maybe find an indy shop to the the pads or do it yourself. Seems like an easy DIY if you're so inclined. Me, I can barely add oil without making a mess so I pay LOL.
Old Jan 20, 2011 | 03:53 PM
PyroKerry's Avatar
PyroKerry has a spectacular aura aboutPyroKerry has a spectacular aura about
Yeah, that seems a bit excessive. The fronts are very easy to replace as the pads slide out of the back of the rotors, so the rotors don't have to be unbolted to replace the pads. The most important thing is to remove the wheel without hitting those PCCB rotors! At least buy the pads from Sunset Porsche, and I'd ask around for a good independant mech in your area who does Porsche work. Any mech who has preped a car for a track day will have replaced Porsche pads.
Old Jan 20, 2011 | 05:21 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
You are absolutely correct they are not a big deal to replace.I wonder how much do they charge for the red calipers break job.
Old Jan 20, 2011 | 05:33 PM
powderjay's Avatar
powderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to behold
How many miles got you to the 50 percent mark? Just curious. Any track time? Tia.
Old Jan 20, 2011 | 08:40 PM
teolax's Avatar
teolax is infamous around these partsteolax is infamous around these parts
+1 on this. Very curious as to the mileage you're at. I have a 08 TT with 17,000 miles and I'm going to replace pads at 50% to save the PCCB rotors. Picked the car up used in December so i haven't had a chance to get the brake pad wear checked yet...
Old Jan 21, 2011 | 08:08 AM
E55AMG's Avatar
I have 45,000 miles now and I replaced them at 50%. I'm not positive but I want to say I had 35,000-38,000 miles at the time.
Old Jan 21, 2011 | 08:57 AM
Clobbard's Avatar
Clobbard is infamous around these parts
My 08 997tt is in for some warranty repairs and the dealer says <a href="http://www.bcduplication.com" style="color: rgb(0, 0, 0) ! important; text-decoration: none ! important; cursor: default ! important;">cd pinting quote</a> pads are still fine at 50%; however, I have seen it suggested on here many times that you should replace them at 50% to lengthen the rotor life.
They are quoting:
WOW very excessive. Should be half that IMO
Old Jan 21, 2011 | 11:06 AM
jasont's Avatar
At 38k now, the fronts are actually at 45% which is 5% less than the rears. I have read from multiple posts that the rears normally wear faster on our cars (contrary to pretty much every other vehicle in the world), something about the brake bias being adjusted for the rear engine. Anyway, that is not holding true in my case.
I believe the first owner tracked the car a number of times, but I have yet to get a hold of him to confirm how much track time it had.
Old Jan 21, 2011 | 01:42 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
what about rotors? If pads are changed as soon as they wear 50% how many pad sets or KMs until rotors need to be changed?
Old Jan 21, 2011 | 02:14 PM
Gotnem108's Avatar
Gotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to all
Pccb rotors will cost you at about $7500 per axle plus labor but you are not going to need it anytime soon, by then, you've probably soils the car.
Old Jan 21, 2011 | 09:31 PM
djben's Avatar
djben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond repute
Unless you are running track days where you are really heating up the brakes, why would replacing the pads at 50% extend the life of your rotors?
If you are running street pads at a DE you are making a mistake anyway, but I digress...
Without excessive heat buildup, the only downside I can see to running the pads low is you might need to ensure your brake fluid reservoir is full?
Someone clue me in, please.
My personal thought is that if I was a dealer, I'd DEFINITELY try and convince everyone, especially Porsche TT owners with PCCB brakes, they they need to replace front and rear pads at 50% life if I was going to get $2340 out of the deal - that's a killer profit!
Old Jan 24, 2011 | 04:34 PM
jasont's Avatar
Good question - if you do a search on here you will find a ton of anecdotal evidence that the rotors will essentially last the life of the car if you change the pads at 50% and do not track the car regularly. Sadly, no one can seem to explain why changing the pads at 50% makes a difference, but they tend to be pretty adamant about it. I'm thinking the chance that changing them early works just might be cheap insurance so I hopefully don't end up replacing $7500/set rotors, but $2300 for a pad change seems more than ridiculous.
Old Jan 25, 2011 | 06:53 PM
tortesq1's Avatar
tortesq1 has a spectacular aura abouttortesq1 has a spectacular aura about
Pads being replaced tomorrow on my 07 with close to 42K miles on her. Being charged just under $1900 for front/rear pads for PCCB's by authorized dealer (including labor). Down to 15% in rear and 25% in front (or via versa as I don't recall). Don't know why dealer waited so long to replace pads, but baby can still brake from 160 plus on a dime.
Old Aug 8, 2015 | 10:52 PM
Guybrush's Avatar
Guybrush is infamous around these parts
How do I know when the pads are down to 50% ? Is there really a mark on the pads like described before? What is the thickness of new pads?
