2005 porsche engine compartment
Old Mar 16, 2011 | 06:33 PM
jpresser's Avatar
jpresser is infamous around these parts
My battery is dead on my 2005 porsche and I've tried using the terminal in the fuse box to get the engine compartment open so I can boost it but when I try this I can only get the switch for the front compartment to open. What can I do??
Old Mar 16, 2011 | 07:34 PM
GU10TG's Avatar
GU10TG is just really niceGU10TG is just really niceGU10TG is just really niceGU10TG is just really niceGU10TG is just really nice
Why don't you boost it from the front trunk compartment? You should use the battery's terminal and a ground near by.
Old Mar 16, 2011 | 09:34 PM
TT Surgeon's Avatar
You only need the front compartment.......that's where the battery is, nothing under the engine bonnet will help you.
Old Mar 17, 2011 | 10:00 AM
jpresser's Avatar
Ok thanks for the help. I figured I could boost it that way but another post was telling me that the battery was in front but the terminals were under the engine compartment because the battery was still to difficult to access.
Old Mar 17, 2011 | 10:51 AM
jhbrennan's Avatar
Here're some pages out of the 996 owners manual that may help.
Old Mar 17, 2011 | 01:42 PM
jpresser's Avatar
thanks I got it boosted. But now I gave it a good drive for a charge and took it back home and the abs lights started flashing and now my car wont even boost...PANIC!
Old Mar 17, 2011 | 01:55 PM
Highlander's Avatar
Highlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond repute
No panic. You probably have a bad battery causing a low system voltage and all the systems go haywire. Replace the battery and I'm sure everything will be fine
Old Mar 18, 2011 | 11:09 AM
jpresser's Avatar
Cool. do I have to replace it with the exact porsche battery? and if so that's probably not going to be cheap I'm assuming....
Old Mar 18, 2011 | 11:14 AM
bumperpip's Avatar
bumperpip is infamous around these parts
jpresser, NO, you don't need a P battery. In fact, nobody does. Get this...go...to...Walmart. Yep. WallyWorld has the battery quite a few on the board use, with universal satisfaction, and many unspent dollars in their jeans.
Old Mar 18, 2011 | 11:17 AM
bbywu's Avatar
Old Mar 18, 2011 | 01:12 PM
Highlander's Avatar
+1 (except the jeans part... )
2lflat4
Nov 18, 2019 05:05 PM
joseph_number1
Jul 19, 2018 05:45 PM
Jun 10, 2017 07:45 PM
Aug 20, 2015 12:17 PM
