Turbo S exhaust in sports mode
Has anyone else noticed that the exhaust note on the turbo S has a bit more rumble when the car is in sport mode?.......Or is it just psychological or that I just simply have more miles on the car now?
When you hit the sport button it opens a baffle in the exhaust and the sound resonates. I love it it sounds great. Also, the great in the PDK get "held" longer and the engine revs higher causing the whole engine/exhaust to sound louder and better!
When sport mode is activated, the engine profile changes - timing, boost, etc. The changes can be heard in the exhaust tone if you listen very carefully at idle. Same reason why on the 997s anyone that had rattle from a LWFW can get it to go away when you push sport mode.
"When you hit the sport button it opens a baffle in the exhaust and the sound resonates." - This is only how the non-turbo version works. Like bbywu said, the turbo exhaust has no baffle it is not mechanical.
I know because I have an aftermarket exhaust and change in sound when in sport mode is more pronounced than it is in the stock turbo exhaust. With the sport exhaust the change in sound is even apparant while driving.
our 4S has factory exhaust with baffles and before I got the brombacher on the turbo the 4S sounded better. Now turbo screams! If you add only one mod make it the exhaust. It corrects the only fault in perfect car. PDK manual downshifts are worth it alone.
