PASM and Sport Mode Failure
Hi folks,
I tracked my car last week and at the end of the day i got "brakepads worn" alert and had them changed (discs, pads, sensors etc.) and when i got it back from my local workshop, the PASM warning lit up. It says "PASM failure" and I can't turn on sport mode on. When I try to, i see "Sport Mode Failure". When I start the engine without moving, everything seems to work fine but as i move like couple of feets the warning comes back again. The suspension stiffens and engine dynamics runs in non-sport mode.
We checked it with PIWIS, in fault codes it says "FR shock absorber" . We took out the FR wheel and looked for the connections and it was ok. We took out the ABS sensor and cleaned it, erase the faulty codes but no help.
Any suggentions ? Before the brakes changed everything was in working order.
Thanks.
Thanks.
what could be the cause for this to happen ?
my car is '08, i guess my warranty has finished :s
Originally Posted by TT Gasman
Should be a warranty item.
Still call your dealer and complain. If car is in good condition, serviced and low miles you might get lucky..
Received the same error message and symptoms with my Damptronics first time at the track. It was raining, PASM locked in stiff mode, the fault would clear when the car wasn't moving, etc. etc. Checked everything and couldn't find a problem. Finally after clearing error codes x3 with a Durametric a week later everything was fine and has been ever since. Who knows what it was. Some hypothesize that it's easy to crimp the PASM wire or that it's prone to shorting when wet. Let us know if you get a definitive diagnosis. Thanks,
The OEM PASM damper is a lot more stout than the aftermarket damptronic version, not prone to failure, chances are that there is a serious issue. Having said that sometimes hitting the bump stop will throw a light, try jacking the car up all the way then let it drop thru its range of travel, if something is stuck it might resolve it. I suppose you have already disconnected the battery to reset?
Originally Posted by THEPUP
Your stock shock is jacked up. The OEM connectors break all the time. If you want to save money you can just splice the wire and bypass the connector.
Try tracking down a Durametric diag tool and it will tell you which shock is giving you the fault. If not a quick trip into the dealer will also help =)
It's unlikely the stock connectors would fail unless they have been altered or misinstalled. They lie under the plastic cover in the front boot, out of harms way. The rear connectors are hidden behind the padding and carpet under the Bose, again out of harms way.
Oct 6, 2015 03:43 PM
