help no boost
Old Jul 26, 2011 | 09:16 PM
jdavis911's Avatar
jdavis911 is infamous around these parts
help no boost
Installed new cargraphic exhaust today. I thought everything went well until test drive. No codes but rough idle and 0 boost at any speed. Also quite a turbo whistle but no go. Could it be I got too much penetrating spray on a sensor or maybe installed an sensor in the wrong spot, not likely was very careful. Some help would be appreciated.
Old Jul 26, 2011 | 09:25 PM
gmoney's Avatar
what did you remove during install?
Old Jul 26, 2011 | 09:33 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Check IC hoses. Sometimes they accidently come loose during install.
Old Jul 26, 2011 | 11:53 PM
jdavis911's Avatar
I removed the intercoolers and 4 sensors to the exhaust. Will check intercoolers in the morning.
Old Jul 26, 2011 | 11:54 PM
jdavis911's Avatar
Is the car ok to drive 10 miles in the morning ?
Old Jul 27, 2011 | 12:09 AM
TTdude's Avatar
Imho, you should be fine. Drive gingerly and don't load it up where you're going to need boost. Your turbos may overspin. Get it fixed asap.
Old Jul 27, 2011 | 06:49 AM
gmoney's Avatar
Def intercooler hose
Old Jul 27, 2011 | 01:51 PM
jdavis911's Avatar
Thanks all, was a loose line however now I can't seem to get it to clip on properly. Looks like it's good then as soon as I tug it pops loose, any suggestions.
Thanks Josh
Old Jul 27, 2011 | 02:20 PM
jdavis911's Avatar
All fixed now, thanks again for the quick help. Previous threads on exhaust installs sure made this easy.
Old Jul 27, 2011 | 05:03 PM
jhbrennan's Avatar
Lots of "no boost" posts recently - seems as if all were fixed by hooking up IC hoses correctly. That's the first place I'll look if it happens to me.
Perkman87
Nov 19, 2015 05:31 PM
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
