Y pipe to throttle body hose keeps popping off...
Old Aug 14, 2011 | 12:07 PM
gmoney's Avatar
Any aftermarket 'upgrades' for this part? Rear y pipe crappy clamp simply slides right off when a bit of engine movement occurs even at lower boost.
I could warranty it but if a better part exists with better clamp would prefer that. Im guessing its failed from being on and off the car so many times.
Old Aug 14, 2011 | 12:53 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I had same problem after installing the IPD Y-pipe. I am also looking for an after Market silicone tube
Old Aug 14, 2011 | 01:03 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
When I had my EVO kit installed, I was told this was a problem with higher boost applications. I believe they installed a connector manufactured by Champion?? that fixes this problem.
Old Aug 14, 2011 | 02:44 PM
milou's Avatar
Is that suitable to stock throttle valve ?
Originally Posted by GreenMotorSport
Green MotorSport 997 Turbo Silicon Hoses! $70
The 997 Turbo Hoses now have an internal bead to ensure a better and tighter seal, $70.
http://www.greenmotorsport.us/servle...e--dsh-/Detail
Check us out at www.greenmotorsport.us or www.greenmotorsport.net
Green MotorSport, LLC
703-896-0582
dgreen@greenmotorsport.us
Old Aug 14, 2011 | 04:13 PM
gmoney's Avatar
Need something for the stock throttle body though...
Old Aug 14, 2011 | 05:43 PM
gmoney's Avatar
ah, so the exterior dimensions of the actual throttle body 'body' are the same thus the silicon hose part fits all? Just to confirm before I order. Thank you!
Old Aug 15, 2011 | 12:21 AM
OneFastBeast's Avatar
OneFastBeast is infamous around these parts
Contact BBIautosport they got the replacement silicone tube for IPD Y-pipe new design. I had the same problem but Betim took care of it.
Old Aug 15, 2011 | 04:22 AM
handdoc's Avatar
handdoc is infamous around these parts
i had the problem w/ my champion y pipe but managed to get the stock one to work, at least for now
Old Aug 15, 2011 | 07:06 AM
Showking's Avatar
Showking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond reputeShowking has a reputation beyond repute
The same thing happened to me after installing the WerksOne Y-Pipe... The guys at Champion sent me a new factory coupling and it's been fine ever since.
-Showking
Old Aug 15, 2011 | 08:26 AM
Botox's Avatar
Botox has a spectacular aura aboutBotox has a spectacular aura aboutBotox has a spectacular aura about
I have same problem with carbon Y-pipe on the panamera. I think they are too stiff, they should make them larger than the IPD plenum, but with a flexible hose on each end to allow for some play with engine movements. Having the entire Y-pipe rigid seems like a flawed concept. Keep the design similar to OEM, but with bigger tubes of the same material, same connectors as well.
Old Aug 15, 2011 | 08:27 AM
gmoney's Avatar
I think the small rubber bead in the factory piece just does not like being removed even a few times, mine was fine for 24k so perhaps just have to chalk this one up to another consumable part!
Old Aug 15, 2011 | 09:16 AM
Showking's Avatar
That's exactly what it is.
-Showking
Old Aug 15, 2011 | 10:04 AM
gmoney's Avatar
anyone know the OEM part number? I think its marked on it but Im in the office, car is at home. Curious to the cost vs. the aftermarket unit.
Old Aug 18, 2011 | 03:32 PM
gmoney's Avatar
Problem solved
https://www.6speedonline.com/forums/...installed.html
NOTE! The IPD hose will NOT fit a stock throttle body, fits 82mm plenum + 82mm throttle body only.
Old Aug 19, 2011 | 04:32 AM
milou's Avatar
This is a different part to the IPD silicone reducer for IPD Y-pipe right?
