IPD 82mm plenum + GT3 throttle body installed
Old Nov 27, 2018 | 04:03 PM
  #46
pdxm5's Avatar
pdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond repute
i tried the ipd y pipe and went back to stock pipe. the 82 TB does add flow but i feel like the pipe is marketing and does 0 for power
Old Nov 27, 2018 | 06:33 PM
  #47
The Bogg's Avatar
I'm using the DO88SE y-pipe which is part of the "big pack" intercooler kit. I have the GT3 tb as well. The coupler from IPD looks decent. I noticed that although my clamp came off the coupling didn't actually come off (unlike the stock one which did come off rarely, on stock tb). I use the Oetiker clamps on the sleeves that go between the ipd plenum and the intake manifold. so far so good with those. I may try them on the ipd coupler if nothing else works...
Old Nov 28, 2018 | 12:29 PM
  #48
Deepstage's Avatar
Deepstage is infamous around these parts
I use an AMS y-pipe that is ridged and wide enough for the clamps to secure to. I also cleaned the coupler with rubber care and made sure the clamp was kept in alignment during the torquing process.
Old Nov 28, 2018 | 02:00 PM
  #49
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Did it make clamping easier or did they just blindly copy the stock one when it came to that part?
Old Dec 2, 2018 | 01:18 AM
  #50
pdxm5's Avatar
I can’t recall if the surfaces were different. My pipe would always blow off from the TB size not the ypipe side. The coupler stayed on the ypipe and slip off the GT3 tb.
Old Dec 2, 2018 | 09:14 AM
  #51
turboslut's Avatar
So my issues seem to lie with a faulty fuel pump for now...my clamps are holding. I'll keep you guys updated. I have had zero pop offs thus far with the constant torque clamps. Fuel trim drama was caught on a log and proves it's not vacuum leak related.
Old Dec 6, 2018 | 11:04 AM
  #52
usrodeo4's Avatar
usrodeo4 is a splendid one to beholdusrodeo4 is a splendid one to beholdusrodeo4 is a splendid one to beholdusrodeo4 is a splendid one to beholdusrodeo4 is a splendid one to beholdusrodeo4 is a splendid one to beholdusrodeo4 is a splendid one to behold
Originally Posted by gmoney
well, after 10 or so WOT runs the freaking hose blew off!!!! Got to be kidding me. I figured it must only be crappy oem clamps. I hit up the local auto parts store and picked up some slightly wider ones, the stock ones were not perfectly round thus assuming not distributing the clamping force well.
Time to test again....
My 997.1 TT has a Turbo build; Tial 68MM Turbos, ByDesign Intercoolers, IPD Y pipe, 82mm IPD Plenum, ID Bosche 1334cc injectors, GT3 TB, Kline headers and exhaust, and I have Trident Marine clamps on my hoses...as recommended by Sam at ByDesign. In all of our WOT tuning tests no hoses blown yet...with the possible exception of the Fuel Regulator hose which can be fixed with a tie down. When you reattach your hose make sure you thoroughly clean the metal of all residue and then once 100% clean and dry, spray some hairspray on it and let it dry to a tack then install the hose and clamp it down, preferably with Trident Marine clamps....again this was from my Tuner, Sam at ByDesign.
Old Dec 6, 2018 | 11:17 AM
  #53
usrodeo4's Avatar
I wrestled with this issue for a long time and tried lots of things, different clamps etc! Evoms $700 solution leaks btw I threw mine in the trash. I went back to new oem clamps and cleaned everything off and aligned them perfectly and it works.
Good to know...
Old Dec 6, 2018 | 11:33 AM
  #54
turboslut's Avatar
yeah I think stock y pipe is what makes this finnicky!
PenguiN
Oct 26, 2018 07:23 AM
PenguiN
Sep 15, 2015 11:44 AM
km90265
Aug 31, 2015 11:00 AM
PenguiN
Aug 21, 2015 10:11 AM
ppwchiang
Aug 20, 2015 10:28 AM
