Parking light bulb replacement on 997 turbo
Old Nov 29, 2011 | 06:18 PM
LittleRed911's Avatar
LittleRed911 is infamous around these parts
Anyone know how to change the front parking light bulb on a 2007 997 turbo?
I don't want to break anything and it is a long way to a dealership. I know it takes a W5W blue vision bulb.
Old Nov 29, 2011 | 06:24 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Are you referring to the side marker lenses?
https://www.6speedonline.com/forums/...placement.html
Old Nov 29, 2011 | 07:22 PM
No, it is the parking light that activates when you use the turn signal switch with the ignition off. It is on the outside end of the LED turn signal array under the headlight. However, I have found the solution. There is a small screw underneath the assembly at the outside end. I had to lay on my back and look up to see it. Once that is removed, the assembly can be slid out and the socket removed. I really liked the way Porsche left me only about 1/2" of slack in the wire harness.
Old Nov 29, 2011 | 07:25 PM
bonehead's Avatar
Ah yes. The small Phillips head screw is nicely tucked out of sight but almost impossible to find unless you know where to look. And yes, there is NO slack on that wiring harness.
Old Nov 29, 2011 | 08:29 PM
jhbrennan's Avatar
Now that you know how to replace it, this LED makes a nice appearance upgrade:
http://www.hoen-usa.com/city.htm
Old Nov 29, 2011 | 08:33 PM
bonehead's Avatar
They are very pretty, but unless they revamped their line and have a little bit better quality control, I'd stay away. I had their side markers, front "parking light" and fogs. One or both of each set failed within a few months of install. FWIW, I do have to say they have EXCELLENT customer service and gave me a refund after I sent them back.
Old Nov 29, 2011 | 10:32 PM
floridaBMW's Avatar
floridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud of
Mine failed pretty quickly also. Put my stock bulbs back in, have yet to send them back to Hoen. Any alternative LED's out there?
Ken
Old Nov 30, 2011 | 02:58 AM
otoppero's Avatar
otoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud ofotoppero has much to be proud of
I did a V-LED's bulb in a soft blue on mine. Looks spectacular, but threw a warning every time I start the car which is annoying. Agree there is no slack on the loom but the job can be done in about 3 minutes per side. If you care about your paint add a few strips of masking tape to the in-board edge connection point on the vehicle as the light seems to want to hit there when trying to wiggle the bulb out.
Old Nov 30, 2011 | 05:53 AM
jhbrennan's Avatar
Ken
Almost 4 months with the Hoen LED's and no problems (fingers crossed) - car is DD.
COBB Tuning
Jan 1, 2025 09:02 AM
MrMiggy
Aug 21, 2015 06:55 PM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
