Cautions in buying a 997 Turbo?
Old Feb 4, 2012 | 07:01 PM
SToronto's Avatar
SToronto is infamous around these parts
Hey folks,
Took a 09 Turbo out today, pretty sweet car.
What are some cautions I should look out for in buying this car? Any known issues?
I've only been researching NA 997.
Thanks!
Old Feb 4, 2012 | 08:37 PM
RNS's Avatar
RNS
RNS is a splendid one to beholdRNS is a splendid one to beholdRNS is a splendid one to beholdRNS is a splendid one to beholdRNS is a splendid one to beholdRNS is a splendid one to beholdRNS is a splendid one to behold
Incredibly strong cars and overbuilt engines. Nothing specific to an 09 TT that needs to be checked out, over and above the regular "used car" homework. Once you learn about the Mezter (GT1) engine in the 07-09 turbos, you won't accept anything else.
As with any used 911, be confident in your purchase by first checking the "big 3" --
1. Pre Purchase inspection (pay to have this done)
2. DME (scan to see if there are any serious over-revs, should be part of the PPI you pay for)
3. the obvious carfax history report for any repaired damage
...and for bonus ask to see a copy of all maintenance receipts (how often the oil was changed, etc)
Have fun with the purchase process. PM me with any questions (did an enormous amount of research before purchasing). They are great cars.
Old Feb 4, 2012 | 09:04 PM
SToronto's Avatar
Thanks for the input on the engines, I had seen a similar reference to the TT engine in the regular 997 section. The rep also mentioned that the TT are different cars in that they are built stronger than the regular 997 - don't yet know if this is true apart from the engine. I may take you up on the PMs. I drove a 09 C2S PDK, 08 C4S 6spd and 09 TT 6 spd today. The only way I can get into the 09 TT is if I trade my Acura, but I think I'll need two cars. So gotta put a bit more thought into the TT purchase. It was really a fun drive, the power...wow..from 100km/h-150km/h effortless and quick to get there.
Old Feb 5, 2012 | 06:34 AM
FadeToBlack's Avatar
FadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of lightFadeToBlack is a glorious beacon of light
Is the car a CPO? If so, you've got nothing to worry.
Old Feb 5, 2012 | 07:16 AM
SToronto's Avatar
It is CPO, the rep actually suggested doing the DME scan especially because its a TT, he said you definitely don't want over revs on this. I was planning on getting a DME record on any car, was surprised to hear him bring it up.
Old Feb 5, 2012 | 08:15 AM
PT Doc's Avatar
PT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond repute
No reason to be surprised he brought it up. It needs to be run to have the car cpo'd. And it won't be cpo'd if it has over revs above a certain range.
Old Feb 5, 2012 | 08:46 AM
SToronto's Avatar
Ok, interesting. I suppose I just assumed with all the recommendations out there to get DME on CPO'd...meant that CPO didn't take that into account. But it makes sense that they would because I've also read on here that over revs at certain range take engine out of warranty for some things or something like that. Unless its also worthwhile to take a look at DME to further scrutinize beyond CPO standards.
I suppose I need to get a checklist of the CPO inspection, does the dealer normally give this to you?
I also drove a CPO 08 C4S with a cracked windshield 10-12cm ...to be replaced by dealer of course.
Old Feb 5, 2012 | 09:24 AM
jhbrennan's Avatar
I'd still ask for a pre-delivery DME readout to attach to your CPO warranty info. Makes it pretty clear that both you and dealer were aware of over revs, if any, at time or purchase. CPO warranty comes with a couple of folders, one of which has a copy of the completed checklist.
Old Feb 5, 2012 | 09:26 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
Although if its a Tip it will NOT have overrevs. Mine was 0s across the board.
Old Feb 5, 2012 | 09:28 AM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
Mine is a tip, had range 1 and very few range 2.
You can still hit the rev limiter with the tip. You just cant miss a shift.
Old Feb 5, 2012 | 09:30 AM
GTEE83's Avatar
GTEE83 is infamous around these parts
Make sure you get a CPO car or an extended warranty. The Mezger engine is not as bulletproof as it has been made out to be. I had to have a camshaft replaced, and luckily it was still under the original warranty. That forced my hand to buy the extended warranty.
Old Feb 5, 2012 | 05:50 PM
SToronto's Avatar
It is CPO. What would that repair have cost?
Old Feb 5, 2012 | 05:51 PM
SToronto's Avatar
Old Feb 5, 2012 | 06:18 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
NO HEATED SEATS WITH THOSE BUCKETS.
IF YOU WANT A CAB the London dealor has a nice silver one.
there are a few turbo's in the Ontario and Montreal dealors
Old Feb 5, 2012 | 07:17 PM
PT Doc's Avatar
Seeing the dme prior to purchase is a must. If someone made an error and your cpo'd 911 had over revs, you old have a huge headache if warranty work ones up. They would be wrong but you would now have to discuss and argue.
