Dectane tailights problem
Old Apr 17, 2012 | 12:08 PM
  #91
PERONE78's Avatar
PERONE78 is a jewel in the roughPERONE78 is a jewel in the roughPERONE78 is a jewel in the rough
The work on taillights was done from my tuner. He have a photos... for info please contact racegaragelab@hotmail.it
Old May 25, 2012 | 02:43 PM
  #92
bbywu's Avatar
Just in case anyone cares, here is the wiring diagram for the tail light harness.
File Type: pdf
Old May 25, 2012 | 02:48 PM
  #93
bbywu's Avatar
After fiddling with my friend's tail light, I have found the following.
The power to each of the 6 pins in the harness activate the various signals in the tail light - turn signal, brake light, fog.
If you step on the brake light, the Dectane "C" comes on. If you turn on the fog light, the side LEDs will turn on. In a perfect world, you want the "C" shape AND the fog LEDs to turn on at the same time.
When you activate both, the middle LEDs will dim. The circuit board inside the housing must be wired to dim the middle LEDs when power is sent to both the "C" and fog LEDs. Without opening the housing, no combination of rewiring the exposed wires will complete the LEDs all around.
If my friend will let me, I'll crack the housing open and figure out how to do it.
Old May 25, 2012 | 03:03 PM
  #94
Carlitos way's Avatar
Carlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really nice
That would be awesome, thanks for trying to find a solution for us it's really appreciated!
Old May 26, 2012 | 02:07 AM
  #95
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
+ rep for Bob. Not only for the research but for being on a mission to sort this thread. :-)
Thanks Bob
Old May 26, 2012 | 08:19 AM
  #96
bbywu's Avatar
Well - I convinced my friend to let me have a crack. I disconnected all the wiring, resistor packs, screws, and baked it for 15 minutes at 200F. The adhesive won't soften. Any higher temps, and I'll damage the LEDs.
Old May 26, 2012 | 09:33 AM
  #97
dianic's Avatar
I am sure that the Italian hack job had to be wires only then.
Was worth a shot thanks Bob. I may email the service man of Perone.
Old May 26, 2012 | 09:36 AM
  #98
bbywu's Avatar
His shop wants $150 for the conversion. My friend already tried.
If it's only wires, I'll keep at it.
Old May 26, 2012 | 09:57 AM
  #99
dianic's Avatar
Let's ask Perone. I am guessing that it was just wires I don't know.
Perone are you still subscribed here? Did your man do wires only? Or did he crack the lights open?
Old May 27, 2012 | 05:12 AM
  #100
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
what about a 3 wire solution. So you run a separate wire from the brake light to the fogs? Would that work? IE the Brake is powering both?
Old May 27, 2012 | 06:06 AM
  #101
dianic's Avatar
I am afraid not. The moment there is power in both, there is some sort of a resistor there which dims the middle row (takes out one of the two lines of led)
Old Jun 15, 2012 | 09:13 AM
  #102
NIKAS's Avatar
NIKAS is infamous around these parts
I've noticed (upon very close scrutiny) that my Dectane LED 997.2 give off an ever so slight humming noise from the rear. Not objectionable noise and pretty quiet, but it's there. Just curious if other adopters have noticed that?
Old Jun 15, 2012 | 03:09 PM
  #103
jhbrennan's Avatar
With the engine on? Everything electric "hums".
Old Jun 24, 2012 | 11:52 AM
  #104
NIKAS's Avatar
This was with the engine off. Perhaps it's the resistor circuitry (or whatever's left of mine), humming away as they do their job.
Old Jun 25, 2012 | 02:14 PM
  #105
PERONE78's Avatar
Are Open!!! not only wire
