Ball Park HP on Tune + Exhaust 997.1TT
Old Jul 24, 2012 | 12:54 AM
Spatia's Avatar
Spatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to beholdSpatia is a splendid one to behold
I just purchased an EP1 from Stef and have completed a Softronic tune on 91 octane pump gas. I generally run Ultra 94 but the variability here in Alberta I stuck with the 91. Anyways - rough numbers - what should I expect for HP and Torque with a Softronic and EP1?
Cheers,
Spatia
Old Jul 24, 2012 | 03:57 AM
TT_Crab's Avatar
TT_Crab has a spectacular aura aboutTT_Crab has a spectacular aura about
Don't worry about numbers on paper as they don't play an important role. I haven't bothered dynoing my car at all. Also the numbers depend on the type of dyno too. I would say you'd probably be somewhere near 550hp. Get a P-box and measure 60-130mph or 100-200km/h taking into account temperature and see how you compare with other cars. By the way you chose the best exhaust available! I love EP exhausts for their power gains AND SOUND. Also I suggest you install a BMC or any other decent drop in filter...! Enjoy your car!
Old Jul 24, 2012 | 02:23 PM
Spatia's Avatar
Would that be at the crank or at the wheels? I know much is speculation however I want to know for general knowledge.
Old Jul 24, 2012 | 02:53 PM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Crank HP for sure on 91.
Old Jul 24, 2012 | 07:03 PM
Swole Powell's Avatar
Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !
I made 550rwhp with GMG exhaust and EPL Tune on pumpgas 93.
Old Jul 24, 2012 | 07:33 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
That's rear wheel hp correct? Meaning the car is running in RWD mode?
Also, how many shifts did you do when you did the 7.3 60-130?
Old Jul 24, 2012 | 07:41 PM
lilindienplaya's Avatar
lilindienplaya is infamous around these parts
Also take into consideration about clutch slippage! I just have the tune and my clutch slips a bit.
Old Jul 25, 2012 | 11:39 AM
Yes that is rear wheel, I pulled the drive shaft for the dyno runs. The car is AWD and full weight 1 shift was used in the 60-130 pull.
Old Jul 25, 2012 | 12:58 PM
Spatia's Avatar
Whats the deal with the advertised 615hp on the Softronic site. Although I only have a 91 octane tune - I run Ultra 94. The flash + EP1 only gets me to ~550hp at the crank. What am I missing here? Other than 65hp...
Old Jul 25, 2012 | 02:17 PM
Spatia's Avatar
Is it me or is the Softronic site completely misleading??? Maybe I missed the part where it referred to the 3.8L DFI car from this site: http://www.softronictuning.com/catal...duct_info.html
Can someone please clarify.
Originally Posted by Neil Switzer
That's for the the 997.2TT 3.8L DFI cars, you should expect about 550HP at the crank.
Old Jul 25, 2012 | 05:28 PM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
yes can someone explain this?
Old Jul 25, 2012 | 08:03 PM
Was it a 3-4 shift or 4-5 shift? What's the rev limiter set at? GMG exhaust is catless? That's a blazing fast for just a tune and exhaust. Any 100-200kph times?
Old Jul 26, 2012 | 12:16 AM
TT_Crab's Avatar
It seems that these claims refer to mk1 models indeed. I wouldn't expect more than 550hp at the crank though with 91 octane fuel. Personally, I chose APR tune along with a BMC and EP1. The car is really fast for a stock VTG car. With 100 octane pump gas it shouldn't be any less than 600+ at the crank. The tune is really reliable and I haven't been having any problems at all. Here in Greece the temperature's 110 degrees or 43 degrees C for quite a long period now and the car is running perfect. Buy yourself a P-box or borrow one to measure 60-130mph. This is a perfect test to see how the car compares to other cars with a tune and exhaust.
Old Jul 26, 2012 | 03:47 AM
johnmiller's Avatar
johnmiller is infamous around these parts
i dont think tune causes a clutch slipage?
Old Jul 26, 2012 | 08:55 AM
IIRC the increase in torque causes pressure plate to slip, I believe you can change out just the pressure plate and keep the stock clutch.
