Whirling Sound on Acceleration
Old Sep 29, 2012 | 08:37 PM
DaBrat's Avatar
DaBrat is infamous around these parts
I'm getting a whirling sound on acceleration (listen to attached sound clip). Anyone know what this may be?
Boost seems to hold ok in general, however, I have experienced sudden drops in boost (which picks up again immediately) especially in 1st gear.
Thanks!
https://docs.google.com/open?id=0B6N...loxbl9sR2d5eEE
Old Oct 1, 2012 | 10:15 AM
gmoney's Avatar
might be wise to list your mods in detail.
Old Oct 1, 2012 | 04:26 PM
sharkster's Avatar
Might be your y-pipe coming off at the throttle body...
Old Oct 1, 2012 | 05:21 PM
DaBrat's Avatar
Werks1 Y-Pipe
Werks1 Intake Box
Champion / Forge DVs
Akrapovic Slip Ons
FVD ECU Flash
And a ton of suspension mods that I think will not be related to this noise.
Thanks!
Old Oct 1, 2012 | 05:23 PM
DaBrat's Avatar
Meaning a problem with the Y-Pipe or a problem with the installation of the Y-Pipe? Reason I ask is I have a brand new Y-Pipe. Thanks!
Old Oct 1, 2012 | 07:29 PM
gmoney's Avatar
rubber adapter from y pipe to throttle body has a tendency to pop off under boost coupled with engine movements under acceleration due to weak hose clamps...especially if removed and replaced a few times.
The bead on the factory hose is terrible, and I would also suggest replacing the hose clamps. Note this may or may note be the cause but definately something worth looking at.
Old Oct 2, 2012 | 04:51 AM
DaBrat's Avatar
Thanks!
The shop just told me that one of my turbos are missing a rod which is used to release air from the turbo. Anyone know what he's referring to? Is it the actuator rod? Weird it just disappeared. Can I just get a replacement without buying an entire turbo? Are there aftermarket rods?
Old Oct 2, 2012 | 08:16 AM
ECS Tuning - Porsche's Avatar
I would assume he's talking about the wastegate rod, it is replaceable if you can find a used junk turbo for cheap, you could take the rod off of that and use it.
Old Oct 2, 2012 | 08:40 AM
DaBrat's Avatar
What if I can't find a used turbo? Any chance I can get a new one somewhere?
Old Oct 2, 2012 | 10:09 AM
If your unable to find a used turbo, you would then have to purchase a new one. We can get ether turbo but would need to know what side you need first.
Old Oct 2, 2012 | 01:15 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Do a Google search for Turbo Rebuilders. I would be very surprised if you can't find a shop that will repair yours..........best,
PV=nRT.
Sep 9, 2022 06:06 PM
Feelgood MD
Mar 24, 2016 09:35 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
Fester
Sep 8, 2015 09:35 AM
