Is this normal?
Old Oct 22, 2012 | 01:28 PM
vinnycg's Avatar
vinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of light
Is this normal?
Yes I'll admit, total Porsche newb. over here. I have a couple questions, that I hope you guys can help with. Coming from owning an e92 m3 for the last four years, I still have a lot to learn about the Porsche. The car is a new to me, 2007 Porsche Turbo, manual.
1. When I start the car for the first time (cold start), I hear a vacuum noise/high frequency whine. It sounds like a system running and doesn't sound like anything mechanically wrong. It also seems timed as it cuts off after 30 seconds or a minute.
2. The motor is not quiet. At idle, you definitely here some metal noises. Again nothing that sounds alarming but just curious as to whether this motor is noisy in nature. I think I read it somewhere but wanted to confirm.
3. Clutch/Reverse. So although I come from a manual m3, I stall like a complete newb, everytime I am reversing into my driveway which has an incline to get up. I usually just turn on the sport mode as it allows for more throttle. Any advice or concerns here? Or is this just something normal to get use to.
4. I have a tire pressure error, that asks if new wheels have been put on. I am not able to find a menu to reset this. Does this mean my TPMS might have gone bad? The tires have the appropriate PSI's in there.
Thanks in advance guys.
I have only had the car for three weeks so still trying to understand and figure it out.
-Vin
Old Oct 22, 2012 | 01:35 PM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
I'm new to the 997tt as well, but stalling in 1st or reverse happens easily if you are in sport mode, the more aggressive throttle mapping makes it much harder to be smooth imo.
Old Oct 22, 2012 | 02:52 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Let me see if I can chime in. I'm also new to the 997TT but I had a 996TT but here are my thoughts.
1. When I start the car for the first time (cold start), I hear a vacuum noise/high frequency whine. It sounds like a system running and doesn't sound like anything mechanically wrong. It also seems timed as it cuts off after 30 seconds or a minute. - I think I have the same sound as well.
2. The motor is not quiet. At idle, you definitely here some metal noises. Again nothing that sounds alarming but just curious as to whether this motor is noisy in nature. I think I read it somewhere but wanted to confirm. - It is noisy...sometimes I feel like it's running with metal in a jar sound.
3. Clutch/Reverse. So although I come from a manual m3, I stall like a complete newb, everytime I am reversing into my driveway which has an incline to get up. I usually just turn on the sport mode as it allows for more throttle. Any advice or concerns here? Or is this just something normal to get use to. - I only reversed up my inclined driveway once and it smelled like burnt clutch so I stopped doing that.
Are you getting an error message? Like this?
Make sure you air up the tires to the recommended pressure and reset the sensors as per the manual.
-Vin
Old Oct 22, 2012 | 02:59 PM
Peskarik's Avatar
Peskarik is infamous around these partsPeskarik is infamous around these parts
-Vin
Try using the handbrake. Once you feel the clutch is grabbing, release the handbrake and be gentle but quick with clutch and gas. On the other hand, as the PrecisionPorsch mentioned, better not back up inclines at all or your clutch will be a real consumable, that could get expensive.
Old Oct 22, 2012 | 03:01 PM
Peskarik's Avatar
I grew up in Stockholm.
Must be really expensive to own a 997T there.
Old Oct 22, 2012 | 04:13 PM
thackl's Avatar
thackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to all
1. Yes, it's the normal startup sound and I wish it always sounded like this at idle. Pretty cool to hear the turbos on idle.
2. Yes, a Mezger engine warmed up sounds like a bucket-o-bolts about to tip over at idle. It's almost embarrassing and a good reason to get and aftermarket exhaust.
3. Practice. It should not be that much of an issue. I've never had it?
4. It looks like it is telling you to add pressure? Check the manual, it should have the correct values..
Old Oct 22, 2012 | 04:41 PM
xbox_fan's Avatar
I only had it for short while but as soon as my warranty is out, I will need to find
a good non-p dealer to take care of her.
Old Oct 22, 2012 | 05:34 PM
vinnycg's Avatar
Thanks. Mine does not even show the diagram. I get the red exclamation sign but not the low pressure sign. I'm starting to think my tpms might have gone bad.
Old Oct 22, 2012 | 05:36 PM
vinnycg's Avatar
Thanks for all the feedback guys. Never been so happy to hear that an engine sounding like a bucket of bolts is normal! As for the clutch, it may require me just getting use to it. It's definitely a different feel from the m3.
-Vin
Old Oct 22, 2012 | 08:00 PM
rossii's Avatar
rossii has much to be proud ofrossii has much to be proud ofrossii has much to be proud ofrossii has much to be proud ofrossii has much to be proud ofrossii has much to be proud ofrossii has much to be proud ofrossii has much to be proud of
That means that new tires have put on and the system has to learn. In the menu you select the tires etc.
Old Oct 22, 2012 | 08:08 PM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
I also have a 2007 Turbo with 6 speed manual:
1. Yes, it's normal and goes away after startup.
2. Yes, a Mezger engine has always had a timing chain noise. Just the way it is.
3. You will get better with the gas/clutch pedals after some time in the driver seat.
4. You will need to replace the tire pressure sensors. The life on them is around 5 years. I replaced mine and all codes and problems went away. Since your car is a 2007 and possibly manufactured in 2006, you are due. Do a search on this forum and you will see many posts on this issue.
Congrats on the Turbo. Your BMW days are over. Remember the Porsche motto: "THERE IS NO SUBSTITUTE!"
<!-- / message -->
Old Oct 23, 2012 | 08:39 AM
gmoney's Avatar
startup noise is the air pump, something to do with reducing emmisions at startup.
Old Oct 23, 2012 | 08:41 AM
vinnycg's Avatar
Thanks dude. I think my salesman had mentioned that as well.
-Vin
Old Oct 27, 2012 | 04:47 PM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
Vin, you dont need to replace all sensors for tpms to work.
The durametric can read how much remaining battery life is estimated on each corner, and show which one is bad. If one is not working, the whole system stops working.
TPMS sensors are made by Beru. I dont recall the part number but a quick google search will get you that info - that is to save from dealer price.
Good luck.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Highlander
Dec 21, 2015 08:42 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
fanporsche
Sep 30, 2015 02:26 PM
