Tire Rubbing Mystery
Old Nov 13, 2012 | 09:45 AM
jrohlf's Avatar
jrohlf is infamous around these parts
I have a 2007 Turbo which came with aftermarket 20" rims. I recently put the stock wheels/tires back on and now the front tires are rubbing against the springs when the car is turning.
I don't believe these cars came with wheel spacers so I'm wondering what is the cause of the rubbing, maybe a wonky alignment or the car has aftermarket suspension parts or failures I don't know about. Any ideas?
Old Nov 13, 2012 | 02:18 PM
jhbrennan's Avatar
By stock you mean 235/35-19 (8.5 width and 56mm offset)? If so, I'd suspect suspension issues. Let us know what you find out.
Old Nov 14, 2012 | 06:07 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Are these coilovers? If so, give one of the tuners a call (TPC Racing, etc.) and ask them for a set of eibach front springs. They are much narrower than for example the Bilsteins and as such allow you to run wider wheels/tires.
Cheers.
Old Nov 18, 2012 | 02:04 PM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
Or add a 5mm spacer?
Old Nov 20, 2012 | 02:15 PM
jrohlf's Avatar
Turns out -1 degree camber was too much for the stock 19" rims/tires but ok for the 20" combo, even with significantly wider tires.
Old Nov 26, 2012 | 07:56 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Were both wheels rubbing or only the driver's side?
This just happened recently to me as well, although only on the drivers side.
And the damage it caused:
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
oo7
Sep 10, 2015 08:08 AM
su_maverick
Sep 8, 2015 11:12 AM
WheelB
Sep 3, 2015 10:26 AM
gabe325
911
Sep 2, 2015 08:10 PM
