Engine light came on today!
Old Nov 30, 2012 | 03:10 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Hi Nick,
In despite of all the advices I'm not sure beeing lean at idle is dramatic: no load at idle so little risk, but only if only at idle...
I would log the car with Durametric to see the lambda after idle before playing with the car.
I run lightly oiled KN/BMCs for years with TT 993/997with no issue...
You told bank2, so it is not the fuel pressure or any "whole" system, yes a Maf could be guilty.
I would switch the right and left Mafs (sensor) and see if the issue follows to be sure...
Let us know...
PS: I'm interested with dead Mafs (sensors) if someone have some, I will pay the shippment.
Old Dec 1, 2012 | 01:08 AM
Frizz's Avatar
Frizz is infamous around these parts
Now I know when you receive the BMC it must be dried for about 2 Weeks. You can simply put it on a heater. Usually out of the box is still too much oil. Now its too late, anyway this ...
Old Dec 1, 2012 | 05:04 AM
jhbrennan's Avatar
That's not true at all - where did you hear that? Heat is not going to help remove excess oil if there were any.
Old Dec 1, 2012 | 06:45 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Have you checked if your lambda sensors are working good?
Old Dec 1, 2012 | 07:21 AM
Frizz's Avatar
The mechanic told me when I got my car back but I´m not an expert with oiled air filters?
Old Dec 1, 2012 | 08:55 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
My Logic tells me like I said before that it could be the MAF's or the Lambda's, I know it's not the BMC filter as I have had them on previous car's and they are not as heavily oiled as K&N's.
What I think is that the car is 6 years old now and some part's are on the way out so when I fit my hybrid turbos in the next few weeks I will change the Lambda's and the MAF's and either clean or replace the filter.
Then I think everything should be just fine!!!
Old Dec 1, 2012 | 10:44 AM
Frizz's Avatar
Anyone thinking about a filter change should read this before
https://www.6speedonline.com/forums/...em-filter.html
Old Dec 1, 2012 | 12:17 PM
faiz's Avatar
faiz is just really nicefaiz is just really nicefaiz is just really nicefaiz is just really nice
get rid of the damn bmc filter asap. then get an electrical cleaner for the MAF (search the forum) and spray away (both copiously) . if you catch it early enough u should be able to salvage the mafs. mine had the same code. cleaned with spray and replaced BMC.
Old Dec 1, 2012 | 12:24 PM
mod mike's Avatar
mod mike has a spectacular aura aboutmod mike has a spectacular aura aboutmod mike has a spectacular aura about
i had the same problem: i got ride of the oiled filter, and with in a few tanks the problem was gone..if you wait too long you'll have to replace the MAF....
GTRNICK's Avatar
What did you replace the BMC with?
Old Dec 3, 2012 | 07:27 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
I don't understand....
Why is this information just coming out of the woodwork now....????
Everyone says bmc is fine... but now it messes up you maf's?
Old Dec 3, 2012 | 04:45 PM
faiz's Avatar
Stock filter
Old Dec 3, 2012 | 04:58 PM
faiz's Avatar
Search the forums and u will see bmc gives no benefit. Also many big hp kits still use stock filter.
Old Dec 4, 2012 | 07:26 AM
mikestyle's Avatar
I understand it makes not benefit except for a little more noise...
BUT why is everyone saying it now causes problems?
I did do some research before buying it and i didn't heard of this... maybe i didn't search hard enough. Can someone refer me to another thread??
Old Dec 4, 2012 | 08:37 AM
jhbrennan's Avatar
Not "everyone" is saying this. I've been using BMC filters on P-cars since 2004 and have never had a problem. Usually MAF problems surface when an over-oiled filter is used.
