Engine light came on today!
Old Nov 29, 2012 | 10:03 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Direct from PIWIS print out.
Fault code - P2190
Description - System too lean at idle bank 2 (below limit value)
Anyone have a clue or has seen this before?
Old Nov 29, 2012 | 11:44 AM
jhbrennan's Avatar
Fault code - P2190
If it came from PIWIS, didn't the OPC have a clue?
Old Nov 29, 2012 | 11:46 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Have not seen this, but lean is a very bad thing for a turbo engine. Be very gentle if you absolutely have to drive the car.
Old Nov 29, 2012 | 11:50 AM
GTRNICK's Avatar
The thing is there is nothing wrong with the car.
There cleared it and it was fine and it has happend a few times over the past year!
I'm think that maybe a sensor/meter is on the way out?
Old Nov 29, 2012 | 03:29 PM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
If you happen to figure it out i just got code p2190 & p2188. Let me know!
I did notice some hesitation on high boost....
I also cleared the codes and it came back two days later.
Old Nov 29, 2012 | 03:59 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
As 512bb points out, lean is a very undesirable operating condition. It can lead to pre- detonation, very high operating temps and things that go bang in the night if run too hard.
What mikestyle is probably experiencing is the ECU pulling timing or cutting boost to save the motor from the lean condition. Ignore the condition and eventually it will put the motor into limp mode.
Best get these issues checked out by a reputable dealer or indy asap. Best,
Old Nov 29, 2012 | 06:45 PM
The Bogg's Avatar
I had these codes and they cleared themselves. It means it's rich at idle. A number of causes and one of them is faulty mafs.
Old Nov 30, 2012 | 02:08 AM
GTRNICK's Avatar
It does smell rich at idle, very rich but assumed it was the cat removal.
Old Nov 30, 2012 | 08:45 AM
Frizz's Avatar
Frizz is infamous around these parts
Your are right, the air mass sensors are not working correct. You need to replace one or the two of them?? Usually this happens after installation of others than OEM Air-Filter?
However, the engine light is correct and says your car needs a new Sensor.
Old Nov 30, 2012 | 10:15 AM
mikestyle's Avatar
I do have a BMC filter....
Maybe I can try a cleaning formula?
On the other hand, i do have codes for both sides.... what are the chances they both went bad at the same time...
Old Nov 30, 2012 | 12:43 PM
Frizz's Avatar
I killed mine with this damned BMC.
It depends on how much oil is applied on the filter. On mine BMC was too much oil, which killed both sensors. The chance both are gone at the same time is fairly high, since each sensor can not withstand any oil.
There is no other chance than replace the sensors /filter and throw away BMC Filters or other oiled filters. After that the engine light disappears!
Old Nov 30, 2012 | 01:12 PM
jhbrennan's Avatar
Too much oil can cause problems...I've been using BMC in my 2008 TT for 4 years and have never had any problems. Just have to use the oil sparingly after you clean the filter and re-oil.
gmoney's Avatar
did you guys clean and oil the filters or was this with them out of the box?
Old Nov 30, 2012 | 01:17 PM
mikestyle's Avatar
Out of the box... have been bmc for approximately 6 months
Old Nov 30, 2012 | 01:49 PM
jhbrennan's Avatar
Usually the re-oil causes the problems - out-of-the-box should be OK.
