Cabin noise
Old Dec 23, 2012 | 12:11 AM
Zero911's Avatar
Zero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to all
Cabin noise
I have had my 997.2TT for about 3 weeks now. 9K miles. CPO. Pristine. It's a PDK and stock.
As my first p-car, I was wondering how much cabin noise is normal? I'm coming from an M5 which was pretty quiet inside.
Less than 30mph sounds fine but on the freeway it's a lot louder inside. I don't believe it's wind noise and all windows/sunroof are closed. It's probably from the engine and I'm not accustomed to having the noise come from behind me.
Note I am *not* complaining about the noise. Just wondering what is normal. Not that I'm going to be listening to much music inside the car but I found that you really can't hear much of the radio once at speed on the freeway.
Thanks!
Old Dec 23, 2012 | 12:55 AM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
Mine is lowered, on 20's and has a header-back exhaust so I'm sure it makes a bit of a difference. But it is pretty damn loud compared to my Cayenne Turbo w/ Techart exhaust. I can do about a 90 minute trip and I'm pretty much ready to gouge out my ears.
Old Dec 23, 2012 | 01:14 AM
997tttiplux's Avatar
997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute
Having a similar e60 background, I too was shocked by the poor road noise insulation of my 997.1.
You'll find on the forum that some people have made some extensive noise insulation work by tearing off the whole interior and applying heavy sticky tar patches. With mild results.
Lastly, I replaced a large plastic cover that is under the floor. While below the car, I tapped with the back of my hand on the apparent steel sheets. They sounded like there was no insulation at all!
So I guess the much easier route is by removing all the plastic panels from the underside, protect all the electric wires, pipes and so on, and cover the whole underside with tar patches and many coats of noise insulating paint.
Old Dec 23, 2012 | 01:18 AM
SeattleBum's Avatar
I should clarify a little. Those 90 minutes of loud noises are AWESOME. Adds to the racecar-like feel. Then the ears bleed and fun quotient goes down a bit.
Old Dec 23, 2012 | 01:54 AM
Sobrut911's Avatar
Sobrut911 is infamous around these parts
The majority of my cabin noise at highway speed are the Pirelli tires. If you search the forum you'll come across posts that talk about varying degrees of tire noise depending on which tire brand you have. I believe some have said the OEM michelins are quieter and the pss michelins (not N2 rated) are even quieter.
Old Dec 23, 2012 | 03:04 AM
I now have michelin pss and it's not quiet.
Old Dec 23, 2012 | 10:55 AM
Zero911's Avatar
Thanks for the responses. I was concerned that something wasn't sealed right but from your responses it sounds like what I'm hearing is normal. In that case, everything's good
Old Dec 23, 2012 | 06:45 PM
arash's Avatar
arash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to behold
Not at all a quiet car. I've considered earplugs for longer trips, but it just sounds so good I never end up putting them in.
Old Dec 23, 2012 | 08:51 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
I look at getting one because they are not that bad on road noise. Try a GTR, they have 20" runflats that howl at highway speeds. And the car has almost no insulation, you hear the rear transmission all the time. A Porsche does have more road noise than any BMW, but overall pleasant exhaust and intake noise are most present and it makes the driving experience enjoyable.
Old Dec 24, 2012 | 12:41 PM
vinnycg's Avatar
vinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of lightvinnycg is a glorious beacon of light
Totally agree with this
Old Dec 24, 2012 | 01:57 PM
BigBen97's Avatar
BigBen97 is a jewel in the roughBigBen97 is a jewel in the roughBigBen97 is a jewel in the rough
Once I put some Michelin PSS on my car it was a lot quieter vs the worn Bridgestones. I drove my car back from Phoenix to Minneapolis with the worn tires. I was too excited to be worried about the road noise but much happier now. Not as quiet as my A6 by any stretch but not intolerable.
Old Dec 24, 2012 | 08:22 PM
kosmo69's Avatar
kosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nice
be thankful you dont have a cab
the 997s are loud. this is the area where the 991 excels.
I do wear headphones on long road trips.
alpha motoring
Oct 2, 2015 12:04 PM
rob4wellness
Oct 2, 2015 07:32 AM
Ronny-
Sep 30, 2015 07:30 PM
