Jacking point replacement
Old Jan 15, 2013 | 10:53 PM
bbywu's Avatar
Does anyone know if the jacking point is simply bolted into place, or is marked area adhesive? It does not appear to be welded.
Old Jan 16, 2013 | 12:54 PM
Macster's Avatar
99.999% certain it is welded (at least spot welded).
Old Jan 16, 2013 | 03:46 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
jack it up from the rear subframe, use that spot to put jack stands.
Old Jan 16, 2013 | 05:39 PM
bbywu's Avatar
I don't have a problem with finding a place to put the jacks. I'm looking to replace the jacking point.
Old Jan 16, 2013 | 06:55 PM
TT Surgeon's Avatar
Isnt it spot welded w body sealer over it for noise?
Old Jan 16, 2013 | 07:30 PM
Macster's Avatar
For noise but based on what I've found with my cars for corrosion protection. The under body metal is painted with what feels like an epoxy based paint that is very resistant to chipping.
It is so important that the lift points be protected by something to prevent this paint from getting crushed and developing cracking. This will be an entry point for water and eventually corrosion.
Old Jan 16, 2013 | 07:32 PM
Macster's Avatar
The only jack points/lift point are the duplicates of the one pictured. Based on my references Porsche doesn't support (no pun) lifting the car any other way, save of course, by the tires/wheels/suspension.
Old Jan 17, 2013 | 09:16 AM
Johnny DB's Avatar
Can you elaborate as to why?
Old Jan 17, 2013 | 12:53 PM
Macster's Avatar
Take the car to a body shop that works on these cars. It may be possible to drill out the spot welds, remove the lifting point pad, and do the same to another car (a wreck) then weld on the new lifting point pad and repaint.
Old Jan 17, 2013 | 09:46 PM
bbywu's Avatar
The flange is bent.
Thank you for your reply. The part is a readily available replacement part, and the lift pad has a threaded insert that is bolted on the corner.
As I mentioned on my previous post, there appears to be epoxy adhesive holding the opposite corner, but the indentations look like spot welds. I have no problem drilling out a those spots, but I was hoping that someone who has done this repair could confirm that they are spot welds.
Old Jan 18, 2013 | 02:43 PM
sharkster's Avatar
It's spot-welded and then the seam sealant is sprayed on there to stop rust. The entire area needs to cleaned (remove the paint etc..) and weld a new one on. You can buy a new piece from Porsche.
Old Jan 18, 2013 | 03:00 PM
bbywu's Avatar
Thanks Alex!
Old Jan 18, 2013 | 03:28 PM
sharkster's Avatar
Thanks Alex!
You bet! I saw that happen on a 07 TT a few years ago... James reminded me!
Old Feb 18, 2023 | 02:14 AM
Jyrki's Avatar
Jyrki is infamous around these parts
removed
timf
Nov 5, 2012 12:09 PM
wowgogs
Mar 5, 2009 12:25 AM
Zuma 911
Dec 11, 2007 07:22 PM
2kuhl
Feb 21, 2005 02:27 PM
Joe Weinstein
Mar 25, 2004 09:20 AM
