Boost controller
Old Mar 16, 2013 | 05:09 AM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Boost controller
Hi guys!
I need a boost controller and I don't want a linear limited value, I want to map my boost according to the rpms.
I noticed only 2 EBCs wich are proposing it:
-Apexi AVCR
-HKS EVC6
Have some guys here experience with one or the other?
Thxs
P.
Old Mar 16, 2013 | 06:24 AM
Aisxos's Avatar
Aisxos is a jewel in the roughAisxos is a jewel in the roughAisxos is a jewel in the rough
I am on the same boat with you.
I ordered hks though.. I havent installed it yet, but i think this is the way to go..
Old Mar 16, 2013 | 07:21 AM
DARTH-VADER's Avatar
DARTH-VADER is infamous around these parts
HKS EVC 6 is the way to go
Old Mar 16, 2013 | 08:18 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Hks is the best way to go , very easy to install but should be tuned well !!!
I installed the TB sensor and controlled the boost by it ! But never tried it on RPM sensor or speed !!
Good luck buddy
Old Mar 17, 2013 | 04:36 AM
K24F's Avatar
Ok guys, thanks for your advices,
The HKS seems a bit more modern too, I will do my choice next week.
Old Jun 17, 2013 | 03:02 PM
K24F's Avatar
Good luck buddy
Ok, I'm about connecting my EVC6, I would like to use the rpm signal to control the boost, do I need to connect the blue wire as well or only the white and ok?
Old Jun 17, 2013 | 03:38 PM
ysfg35's Avatar
To be honest i could not install the RPM sensor on my 997tt , i just ran the TB sensor , if you need help installing and wire it , please let me know , i will be happy to help you
Yousef
Old Jun 17, 2013 | 03:57 PM
K24F's Avatar
Yousef
Thxs Yousef,
I guess I will do the opposite: only rpm signal, a throttle issue because a wiring mistake or else scares me (imagine the throttle wide open by error, no cable to close it and >750 hp)
I will probably have questions when tune it.
P.
Old Jun 18, 2013 | 01:41 PM
K24F's Avatar
Uhhhh,
We found the right throttle pin but not the rpm signal
Does someone knows which pin is it to rpm signal?
Thxs
Old Jun 18, 2013 | 02:58 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Which turbos did you go for and how much boost are you going to run? Do you have pics of install please?
Old Jun 18, 2013 | 03:13 PM
K24F's Avatar
You have a Pm Nick
Old Jun 19, 2013 | 01:07 AM
Aisxos's Avatar
Uhhhh,
Thxs
I want to learn that too.... I believe though only Emre knows
Old Jul 24, 2013 | 01:46 AM
Aisxos's Avatar
any news with the boost controller !? Any updates ?! I am afraid i will buy also Greedy if i am not sure for the setup...
Btw i believe my engine will be ready in 10 days..
Old Jul 24, 2013 | 03:47 AM
MegioN's Avatar
MegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to all
Guys, if you want to make boost by gear or boost by speed go with Blitz ID Spec R + Power Meter ID, its very easy to tune and work perfect.
Old Jul 25, 2013 | 01:47 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hi Nick,
Will send you information soon
Cheers,
Emre
