Any springs lower more than 20mm?
Old Apr 17, 2013 | 11:37 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
Curious if anyone knows of a spring set that goes lower than 20mm?
I've had H&R on my past 997 and I wanted it lower
Old Apr 18, 2013 | 07:04 AM
TT Surgeon's Avatar
I think lower than 20 and you'll have shock bottoming out issues.
Old Apr 18, 2013 | 07:43 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
H&R springs for the 997 Turbo lower the car 1 inch (25mm). On the Carrera models they lower 1.2 inches (30mm), so if you weren't happy with the drop on that car, definitely don't get them for the turbo.
We use them A LOT of Turbo cars and I personally think the drop is perfect. Gets rid of the nasty wheel gap, and still rides more or less like stock.
Old Apr 18, 2013 | 10:45 AM
32krazy!'s Avatar
quick hijack! any suggestions for springs for my jrz coilovers? i have 600/800 on the car and its to harsh. want to geta more compliant ride, maybe 500/700?
Old Apr 18, 2013 | 01:54 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
any shock degradation noticed on them?
Old Apr 18, 2013 | 07:46 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Gotta say that coil overs, either kwv3's or Bilsteins will be the way to go. That way you can go lower and after you rip off two splitters, you can raise it back up .
Old Apr 19, 2013 | 06:05 PM
C4SxM5's Avatar
Had bilstein on my past 997tt and to be honest they don't go that much lower. Wasn't worth the extra cost for me.
Old Apr 20, 2013 | 12:30 PM
cannga's Avatar
It's worth a try, even 400/600, but I would call JRZ first and see what the lowest spring rates they would recommend. The JRZ dampers are designed for higher spring rates and there is a limit as to how low you could go with the spring rates. Each particular damper, whether JRZ, or Bilstein, is designed for a limited range of spring rates you could try; small variation is ok, big variation is not a good idea unless you re-valve the damper, and even so success is not necessarily guaranteed.
Even so, it may not help, as it's the dampers that are also responsible for suspension stiffness, and the construction of spring hat/bearing/spring seat itself (*maybe* less rubber gasket, more metal, but I am not sure about this). Someone here had JRZ and eventually had to take it off for the same problem you are having - a superior system for track junkies but simply too stiff and unforgiving for street driving.
Texas1
Sep 20, 2015 09:12 AM
BLKMGK
Sep 19, 2015 03:51 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
Taxthe1%
Sep 10, 2015 09:33 AM
