HKS EVC6 wiring question!
Old Dec 26, 2013 | 10:38 AM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Sure,why not. I can probably can learn something.
Old Dec 26, 2013 | 11:32 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
pm sent
Old Dec 26, 2013 | 03:05 PM
GT996's Avatar
Thanks. I have finished the camshaft sensor line tapping and will test it tomorrow.
Andreas
Old Dec 27, 2013 | 04:23 AM
GT996's Avatar
It works much better than my can bus solution Time for a test drive with my new boost controller.
Old Dec 27, 2013 | 09:33 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
anyone did boost by speed ???
Old Dec 27, 2013 | 09:37 AM
Bro,boost vs rpm is the best.
Old Dec 27, 2013 | 09:38 AM
perfect
Old Dec 27, 2013 | 09:51 AM
ysfg35's Avatar
i like the idea od running low boost settings till i reach 120km/h then get high boost to avoid tires slipping and traction issues etc etc ..
Old May 15, 2018 | 07:23 PM
The Bogg's Avatar
do you want to run boost vs rpm?if you want i have a video showing step by step how to set it.
Bump for this helpful thread!
If you still have that video could you send it to me? or post it here?
Old Oct 25, 2025 | 07:15 AM
Xander's Avatar
Xander is just really niceXander is just really niceXander is just really niceXander is just really nice
i am running evc5 ,RPM just read true value when i set it to 4cyl.and hooked the hks rpm wire to the camshaft sensor wire not cranckshaft sensor!
Bumping a 12 year old post for a project saver on my 997tt "build"!
After installing xr1000s in my car, having a faulty boost controller that was on 5 month backorder, installing a whole new controller setup and not being able to find an RPM signal to do boost by RPM, this post solved my issue.
Tapped the Red wire with a gray line, middle plug on the ECU, 4 cyl setting on the boost controller and it works!!!!
Thank you so much for the info!!!! time to put the interior back together and get back to tuning for more power.
X...
Enclavet
Oct 30, 2018 12:32 PM
Fadi
Sep 9, 2013 06:09 PM
Mgib
Jun 25, 2010 01:32 AM
Retsujou
Feb 8, 2010 02:01 PM
Turbo Fanatic
Jan 8, 2009 07:00 PM
