HKS EVC6 wiring question!
Old Jun 18, 2013 | 02:04 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Hi Speeders!
My Alpha kit is bolted now, the car only ran at idle for now and it stays one thing to do:
Connecting the rpm signal from the ECU to the HKS EBC, does someone know which pin?
For now we connected the C46 and the HKS shows 14000rpm at idle!
Thxs for your help!
P.
Old Jun 18, 2013 | 02:11 PM
DaveM@EPL's Avatar
DaveM@EPL is just really niceDaveM@EPL is just really niceDaveM@EPL is just really niceDaveM@EPL is just really nice
Since you are running it off the coil trigger signal for a single cylinder, you'll have to set the number of cylinders to 1 in the setup. Problem is the EVC has some trouble reading a clean signal for RPM at full load..
Old Jun 18, 2013 | 02:19 PM
K24F's Avatar
Thxs Dave,
We set the number of cylinder to 6...
Do you mean the rpm input with the HKS isn't the way to go to control the boost with?
Old Jun 18, 2013 | 02:28 PM
DaveM@EPL's Avatar
It hasn't worked to well for RPM based boost because the signal isn't square wave and maxes rpms out at 14000 with a lot of load on the motor, but it works great for a fixed boost control. If you're going to use it for RPM based boost, you'll need to find a way to emulate an old fashion square wave tach signal from the canbus with an adapter.
Old Jun 18, 2013 | 03:00 PM
K24F's Avatar
Really?
A Profec should be enough so, if only a fixed boost value is usable with my hks on the 997TT without electronic mods...
Old Dec 25, 2013 | 04:08 PM
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Hi,
today I have finshed my boost controller installation (HKS EVC 6) and I also have installed a CAN bus converter in order to get a cleaner RPM signal. I can't test today, but the LED of the module shows it locked to the bus correctly and "knows" the car. Tomorrow I will see if the RPM signal is ok.
I could need some help in order to save some time. Connector 3 of the ECU has 2 throttle position sensor lines (Pin 8 = sensor 2, Pin 24 = sensor 1). In understand one is the pedal value and the other one the throttle plate value.
Which one is the throttle plate value? I like to have that input for the boost controller.
Andreas
Old Dec 25, 2013 | 04:24 PM
GT996's Avatar
I just see that the reply went to the 997 forum. My car is a 2002 996. Shouldn't make a difference.
Old Dec 25, 2013 | 10:42 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
i am running evc5 ,RPM just read true value when i set it to 4cyl.and hooked the hks rpm wire to the camshaft sensor wire not cranckshaft sensor!
Old Dec 25, 2013 | 11:22 PM
GT996's Avatar
Nice idea. Did you have any problems with the rpm signal on high loads / top end?
Did you also use the throttle plate signal and if so, where did you connect the wire to?
Old Dec 25, 2013 | 11:58 PM
RPM reading is 100% accurate from idle to redline.i never used throttle signal,the only wire i hooked to the ecu is the RPM signal.
Old Dec 26, 2013 | 12:21 AM
Here you go.
Old Dec 26, 2013 | 01:16 AM
GT996's Avatar
Thank you That's the camshaft sensor 1. I will give it a try or even compare to my CAN bus solution.
I will measure the cables to the throttle body and see which pin on the ECU to use for that feature.
Andreas
Old Dec 26, 2013 | 01:19 AM
Andreas
willkommen
Old Dec 26, 2013 | 07:47 AM
GT996's Avatar
Connector III pin 24 (yellow/white) is the signal to use for the throttle signaling. It goes from about 0.7 V to about 4.4 V.
Pin 8 is doing the opposite: it reads 4.4 V with no throttle and goes down to 0.7 V on full throttle.
My CAN bus signal is working, but the signal is not stable enough. I will try your suggestion now.
Andreas
Old Dec 26, 2013 | 09:55 AM
do you want to run boost vs rpm?if you want i have a video showing step by step how to set it.
