Torque solution products
Old Sep 10, 2013 | 05:12 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Hi guys I am ordering the coolant fix from them as I have the notorious leak and I'm thinking of ordering these products below and I wondered if anyone has fitted them to their cars yet and had a good experience?
I wanted to know if there is any extra vibration or any cons vs pros that you came across?
Street transmission inserts,
Subframe bushings.
Cheers,
Nick.
Old Sep 10, 2013 | 10:39 AM
roybotnik's Avatar
roybotnik is just really niceroybotnik is just really niceroybotnik is just really niceroybotnik is just really niceroybotnik is just really nice
Those exhaust mounts won't do you any good since the exhaust mounts directly to the engine and the support frame that connects to the engine mounts. Not sure why they have those listed when you select 997 turbo. Interested in the shifter bushings though.
Old Sep 10, 2013 | 10:43 AM
GTRNICK's Avatar
You know what I was thinking the same thing about the exhaust mounts as the exhaust is strapped in.
I was having a newb moment.
Old Sep 10, 2013 | 11:12 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I believe those TQ solution coolant pipes were designed primarily for 996tt? I had to get Betim at BBI to replace the one's the didn't fit on the 997t. You might want to contact him for a complete set for 997t.
Old Sep 10, 2013 | 11:46 PM
GTRNICK's Avatar
Hmmm thats interesting TTdude.
Thanks for the heads up as they never mentioned this at all.
I will contact Betim.
Cheers.
Old Sep 10, 2013 | 11:57 PM
TTdude's Avatar
Cheers.
Yeah really
Old Sep 10, 2013 | 11:59 PM
GTRNICK's Avatar
Yeah really
Yup and the thing is if that happened to me while my engine is out that would of caused major problems and delays.
So a big thanks again and a rep point
Old Sep 11, 2013 | 12:04 AM
TTdude's Avatar
Yeah, caused me delay too. Look at the long one on the left (reused stock) and then the very small one (second from the left) -- that's not in the kit. Betim supplied that one. The others are TQ solution pipes. So I shouldn't be too critical. Most of them fit.
Old Sep 11, 2013 | 12:10 AM
GTRNICK's Avatar
So whats to stop me from welding the stock ones in place?
P.S. I'm seriously thinking of going 3.8ltr or 4.1ltr now my engine is out
Old Sep 11, 2013 | 12:17 AM
TTdude's Avatar
Oh man Nick, you got the disease...
You can't just weld stock pipes "as is" because of the epoxy. It melts and causes a mess and screws up the weld. So you have to carefully remove the pipes and clean all surfaces thoroughly. Removing the stock pipes can cause damage to them if you're not careful.
Good luck in advance with the build.
Old Sep 11, 2013 | 12:27 AM
GTRNICK's Avatar
Dude I've unfortunately had modders syndrome since I got my license in 1998
I saw this video on YouTube last week.
So if Torque Solutions cannot confirm the kit they are trying to sell fits 997tt then I will probably go down the YouTube video route.
Old Sep 11, 2013 | 12:39 AM
TTdude's Avatar
Nice vid. Hadn't seen that before. JB comes thru again! Looks like solid repair.
Old Sep 11, 2013 | 12:51 AM
GTRNICK's Avatar
This is why I love this forum as it helps you channel your decisions in the right direction.
Now this this thread is around I hope it will help people to do the same thing.
Just takes a bit of patients aye. I always tell people including myself to be patient as the rush/quick route is an expensive one which I have learnt over the years!
Old Sep 11, 2013 | 12:55 AM
TTdude's Avatar
Amen. Good post. Tried to rep but it says I need to spread the love around. If they can do it in 4 hours and it holds, that's really great. You'll save on the parts.
Old Sep 11, 2013 | 01:29 AM
GTRNICK's Avatar
Yes it gave me the same message when I tried to rep you too
And yes it great that you don't really need the extra parts and if you follow the method on YouTube you can still weld them instead of using the bonding agent.
Sep 10, 2015 03:20 PM
Ferrari
Aug 24, 2015 04:35 PM
