My horn failed and now the antifreeze smell is gone!
Old Sep 16, 2013 | 08:47 PM
tomb18's Avatar
tomb18 is a jewel in the roughtomb18 is a jewel in the roughtomb18 is a jewel in the rough
Brought my car in to the stealership a few weeks ago with a smell of antifreeze. Kept it and pressure tested it and said nothing was wrong. My luck, my horn failed so I made an appointment to have them fix it as soon as I brought the car in. I made sure it was nice and hot. Guess what, they found the leaky rad.
Okay, so for the 997TT the usual things that go wrong are
1) Seized boost actuator: Had that
2) Failed low frequency horn: Had that
3) Leaky rad: had one
4) Failed hydraulics in the wing: Had that
5) Second gear pop out: just started
6) Cam shaft position senor: One P2100 error but hasn't come back and the jury is out as to a throttle sensor or cam sensor.
7) Clutch pedal starting to get really hard to push in the morning: Accumulator
Have I missed anything? 10 months left on the CPO but 5 months of that time it will be in storage. 24,000 miles on the car.
Well I look on the bright side....if the cam will wait until the coolant hoses pop on the engine, then I'll kill two birds with one stone.
Love the car, but whoever said these cars are reliable must be dreaming.
Old Sep 16, 2013 | 10:07 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Ouch. I just had the p2100, did hot oil change and it hasnt come back(fingers crossed)
I didnt think 2nd gear popout was an issue with the 997TT, I know it was bad on 2001 and 2002 996TT.
Old Sep 16, 2013 | 11:02 PM
tomb18's Avatar
Well, now the 2007's are starting to get older so 2nd gear pop out may a start showing up more.
Old Sep 17, 2013 | 11:10 AM
maverick997's Avatar
maverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to allmaverick997 is a name known to all
Tomb18 did you see any evidence of the leak in the radiator? I have a continual smell and have had the system pressure tested at least 4 times over the last couple of years. I also had my horns replaced and the accumulator and power steering pump. Have 24k miles.
Old Sep 17, 2013 | 05:03 PM
plinc's Avatar
plinc is infamous around these parts
At about ~28k mi (give or take) I had the ol' "coolant hoses pop out of the engine" routine. This happened about 500mi after the leaky radiator, so you have that to look forward to.
Old Sep 17, 2013 | 06:10 PM
tomb18's Avatar
I know. But there is a class action suit against a porsche for that. I believe they will now fix it for free or reimburse you
Old Sep 17, 2013 | 06:14 PM
tomb18's Avatar
No other sign except for the smell. I did make it clear that the smell was coming fom the left front and made the service guy smell it. I told him I didn't want to have to come back a third time.
I find porsche needs to have firm pressure for them to do anything up here in montreal. Even then the car sits around a lot without anything being done. Actually the worse service e perform ves I have had in over 30 of car ownership.
Old Sep 17, 2013 | 09:37 PM
The Bogg's Avatar
You missed rattling quarter panel windows, lol. Thank god for cpo though! I had many of those things. My accumulator was replaced last year, about 5000 kms ago and is starting to act up again. Unfortunately, cpo gone and service guy not sure if it would be replaced for free.
The p2100 error is intermittent. Mine started out that way...had camshaft replaced last year and nothing since. And I must say it felt noticeably faster afterward.
Old Sep 18, 2013 | 05:53 PM
tomb18's Avatar
My car is still at the dealers waiting for two new hoses. Seems the person before me had wider tires and they rubbed on the upper radiator hose. Very close to perforating.
I have to pay for that though,since my wheels are after market. I have 20" 8.5"wide 55mm offset and 30 aspect ratio tires. Same size as stock. Must have been the owner before.
vpr80
Mar 6, 2021 12:11 PM
mxracer
Dec 28, 2015 08:17 AM
Jd1368
Oct 16, 2015 09:48 AM
Im4citadel
Oct 5, 2015 09:04 AM
Mz3bo
Oct 1, 2015 06:32 PM
