occasional stall on start-up
Old Oct 11, 2016 | 10:00 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
Originally Posted by au2bahn
Fuel pump?
The attachment in the above post is for an out of adjustment "pulse sender"
Old Oct 15, 2016 | 04:03 PM
Black Betty's Avatar
Black Betty is infamous around these parts
I have not had another Start & Stall incident since I re-installed the air ducting and tightened it correctly as last posted. It's been quite a while and have had air ducts off 2-3 times since for maintenance / mods. You don't need to torque the clamps till they twist, but they need to be tight, it's a "feel thing".
I always apply a very-light wipe of grease inside the hoses. Can help to seal it up and makes it much easier to remove when needed. No blobs or gobs or you will ****-off sensors. I'm going to say, it was the cause of the Start & Stop issue for me.
Hope it works for you !
DYL 911
Oct 1, 2015 02:47 PM
oo7
Sep 10, 2015 08:08 AM
Blue Chip
Sep 10, 2015 07:07 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
