Gt2 slave conversion question
Old May 26, 2014 | 09:36 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
I want to do the conversion using the factory stuff including drilling the trans.
Anyone have a parts list and possibly am how to?
Thank guys
Old May 26, 2014 | 12:53 PM
Thenewguy's Avatar
Thenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of lightThenewguy is a glorious beacon of light
Thank guys
AMS has a kit for a full conversion. That's what I had my shop use
Old May 26, 2014 | 01:03 PM
93ls1rx7's Avatar
I think Ams uses the same style of conversion as EVOMS with the aftermarket bracket. I am trying to find one that drills the case.
Old May 26, 2014 | 01:43 PM
32krazy!'s Avatar
Old May 27, 2014 | 12:53 AM
93ls1rx7's Avatar
32krazy, thanks a million. Apparently my google and search skills are lacking!
Old May 27, 2014 | 04:54 AM
32krazy!'s Avatar
when you do this before you really do anything flush the system from the reservoir to the slave with lots of dot 4 fluid. petosin is corrosive to rubber and you will kill your new slave of you don't. relatively easy conversion its the reinstall lining up the clutch rod and fork thats a major pain
Old May 27, 2014 | 10:35 AM
93ls1rx7's Avatar
So just to clarify, all you need is the gt2 slave, gt2 fork and new fluid?
Old May 27, 2014 | 01:17 PM
TurboRexed's Avatar
TurboRexed is infamous around these parts
I went the AMS kit route...
Old May 27, 2014 | 02:35 PM
32krazy!'s Avatar
gt2 master cylinder,gt2 dot 4 reservoir cap, gt2 hyd line, gt2 slave, gt2 clutch fork. if your wanting it exactly like the gt2 your also going to need the gt2 power steering pump and reservoir. or drill and tap for plugs on the oem unit. 2 studs with nits. dot 4 fluid. gt2 spring assist if you want. i just used a alb spring from home depot.
approx 600$ worth of parts plus labor
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
ECS Tuning - VW
Aug 26, 2015 02:54 PM
TrackOne
Aug 20, 2015 12:56 PM
