997.1 with PCM3 iPod/iPhone connection
Old Jun 19, 2014 | 10:04 AM
valor's Avatar
valor is infamous around these parts
hi folks!
I've got 09 997.1tt, with PCM3(I guess it is 3, because it has touch screen). Cant figure out how(if possible) to connect my iPod/iPhone to the system to play music from iTunes library. Please help
Old Jun 19, 2014 | 08:40 PM
egreaves20's Avatar
egreaves20 is a jewel in the roughegreaves20 is a jewel in the roughegreaves20 is a jewel in the rough
In center console, use AUX port which plugs into your phone Headphone jack. Chose AUX in PCM as source and music will play through speakers. That's the easy way.
Old Jun 19, 2014 | 08:59 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Porsche makes a proprietary plug that connects to the USB and the iPod connector and then the iPod or iPhone itself. Suncoast has then. I bought mine for $35 delivered from eBay.
Old Jun 20, 2014 | 12:07 AM
valor's Avatar
hmm, the issue is, I cant find AUX input socket According to owner's manual it's supposed to be hidden in the box between the seats, but it's not there.
Old Jun 20, 2014 | 12:22 AM
kittivan's Avatar
kittivan is infamous around these partskittivan is infamous around these parts
You have a 2009 right? It should be in the center compartment just behind where the ashtray is. Should be writing. You need the actual plug though.
Old Jun 20, 2014 | 12:24 AM
kittivan's Avatar
can take a picture of your center console open and post it? Odd that it wouldn't be there. I also have an 09' turbo and it's there.
Old Jun 20, 2014 | 04:20 AM
valor's Avatar
It's 09 MY, however production is end of 2008. In the center compartment I have only AV socket, no AUX. I will make photo and post later.
Old Jun 20, 2014 | 06:19 AM
vivid's Avatar
vivid is a jewel in the roughvivid is a jewel in the roughvivid is a jewel in the rough
it was an option.... sad but true... I found out the hard way too went I picked up my 09.
You can order it and have it installed. The best price I could find is here Universal Audio Interface (99704490234) $336.24. Dealer will probably charge a couple of hrs for install, even though it should take about 45mins at most.
Old Jun 21, 2014 | 12:43 PM
deaddana's Avatar
deaddana is infamous around these parts
and......
and the sound is horrible! unless my 08 is different. it goes through an fm modulator , a weak one at that. full of static and you have to crank it to hear a song. poor sound quality , and im no audiophile. nissan xterra sounds like a concert hall by comparison.
Old Jun 21, 2014 | 12:50 PM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
for pcm3 it is NOT fm-modulator.
Old Jun 21, 2014 | 01:16 PM
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
Correct - the PCM3 the universal audio is hardwired and supports iPod controls via PCM. With the AUX input you cannot control or charge the device and the sound is not as good, but on the plus side you don't need the expensive proprietary cables/adapters.
Old Jun 21, 2014 | 03:49 PM
vivid's Avatar
It is different. Although the 09 is a .1, it did receive the updated interior of .2, which included the updated PCM3.0, from the older PCM2.1. You are correct that with the 08 (PCM2.1) the aux/iPhone was FM modulated, but that is not the case with the PCM3.0
Old Jun 21, 2014 | 04:45 PM
deaddana's Avatar
then you guys are so lucky
i have a glovebox full of burnt cd's.
Old Jun 22, 2014 | 03:11 AM
Serg124's Avatar
install yourself pcm3.0
what you mean - luck? I have pcm3.0 with dvd-changer and full glovebox of original music dvd - quality cant match to mp3
werkzrs
May 3, 2026 01:20 AM
VID997
97
Mar 20, 2018 02:23 PM
