997.1 Turbo just shuts off - ideas?
Old Sep 25, 2014 | 12:28 PM
cby1's Avatar
cby1 is infamous around these parts
Hi All,
Wondering if anyone has experienced the same weirdness I have.
Twice in the last 2 months, I was sitting at an intersection, idling in Neutral (6M tranny). With no warning, no rough idle, nothing - the car just shuts off, and displays the message "PSM Failure" on the dash display. Car starts right up, and then it's fine - mostly. Additional info:
- No codes seen by shop
- Battery replaced by shop after 1st occurrence - still happened
- First time PSM was OFF, second time it was ON
- First time, PSM button was NOT operational after restarting the car, second time it WAS operational (i.e., you could toggle back and forth).
- With the first occurrence, PSM button did eventually work after restarting the car the next day (so 2nd start after incident).
Mods:
- EVOMsit ECU flash
- EVOMS "quiet" hi-flow exhaust
- Stage 2 Clubsport clutch, with lightweight flywheel
- GT2 Slave Conversion
Any ideas? Anybody experienced this?
Thanks.
Chris
Old Sep 25, 2014 | 12:40 PM
garychios's Avatar
garychios is a splendid one to beholdgarychios is a splendid one to beholdgarychios is a splendid one to beholdgarychios is a splendid one to beholdgarychios is a splendid one to beholdgarychios is a splendid one to beholdgarychios is a splendid one to behold
PSM failure means the ECU stopped communicating with that module. Sounds like a problem with the ECU or other module in the car.
Old Sep 25, 2014 | 01:10 PM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
Have you checked the PSM module as well as the ECU for faults?
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Sep 25, 2014 | 02:46 PM
997tt+C63's Avatar
997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold997tt+C63 is a splendid one to behold
Anybody know where the PSM module is located.
Old Sep 25, 2014 | 03:32 PM
It's the same unit as the ABS controller, located under the trims in the front trunk.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Sep 25, 2014 | 04:37 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Maf problem
Old Sep 25, 2014 | 07:50 PM
jjurroz's Avatar
jjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant future
I had this same issue happen to me 4 times. I cleaned out my MAfs and the issue went away. I would sometimes get codes and sometimes not. Car would just stall while idling at a light.
There are ways to diagnose the MAfs with a durametric and checking voltages. MAF cleaner is 3.99 at a local auto parts store and takes literally 10 mins to clean both, so it's worth doing regardless.
-Jose
Old Sep 26, 2014 | 05:30 PM
cby1's Avatar
Hey thanks everybody - some great ideas here.
Shop checked for codes, found none. I like the MAF idea - that makes a lot of sense.
Are you guys saying that there's a separate place to check for PSM codes (as opposed to "regular" ECU codes)? Clearly, I'm not a mechanic :-(.
BTW, this is a 2008 997.1 with 26K miles, if that helps - can't believe I left that out.
Thanks,
Chris
Old Sep 26, 2014 | 07:55 PM
Lysoleverywhere's Avatar
Lysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really nice
I had this issue on my 996TT. The venturi tubes needed to be replaced in the fuel tank. Also replaced the fuel pump while I was at it.
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
MrNurse
Sep 10, 2015 09:44 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
oddjob142
Aug 19, 2015 12:27 PM
