help 997.1tt sudden boost drop
Old Jan 25, 2015 | 04:38 PM
cfpchfc1's Avatar
cfpchfc1 is infamous around these parts
Hello, Everyone.
my car just lost boost from 21psi to 7 while accelerating. It will not go above 7 anymore.
Suggestions?
Old Jan 25, 2015 | 04:41 PM
jhbrennan's Avatar
Originally Posted by cfpchfc1
Hello, Everyone.
Suggestions?
The obvious first - boost leak - check all your hoses/connections.
Old Jan 25, 2015 | 05:01 PM
cfpchfc1's Avatar
thanks. I don't know if the leak is large would it still build any boost?
Old Jan 25, 2015 | 05:41 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Were you accelerating hard when it happened? Did you hear a "pop" ?
Any check engine lights come on?
As indicated, usually a leak. Places to check is Y-Pipe to IC's, Y-Pipe to throttle body, Lower hose from cool side turbo to IC's, or even recirculating valve tubes...Those are the most obvious..
DC
Old Jan 25, 2015 | 07:18 PM
cfpchfc1's Avatar
DC
Actually, I had just shifted to 5th and at 137mph, heavy power loss . No "pop", but the exhaust was screaming . It will build boost, not beyond 7psi. I guess I'll find out in a couple of days when it goes to the shop.
Old Jan 26, 2015 | 03:31 AM
TheInfamousDrew's Avatar
TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !
DC
+1
This happened to me the other day during a spirited drive. The Y pipe popped off of the throttle body.
Simple 5 min fix.
1. Loosen hose calmp
2. Push Y pipe back in to boot
3. Tighten hose clamp
Old Jan 26, 2015 | 05:37 PM
cfpchfc1's Avatar
Just checked, no visible problems. shop tomorrow
Thank you all
Old Jan 26, 2015 | 07:18 PM
therock88's Avatar
Thank you all
Report back what you find out...as it will help others, and help us all better Dx issues for members...
Good luck...I hope it is nothing serious.
As I was thinking about it, I was also wondering if one or both of the VTG actuator rods came loose or stuck? That may have these symptoms as well...
DC
Old Jan 27, 2015 | 04:51 PM
cfpchfc1's Avatar
DC
Today, after the car rested, resumed normal operations.
I have no idea what's happening. Next week it will be at the shop
Old Jan 27, 2015 | 05:16 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Welcome to the not-so wonderful-world of "limp mode". If it's not a boost leak there is some other problem that the ECU detected and put the car into limp mode (cut boost and probably a bunch of other stuff) to save itself. When you "rebooted", ie restarted the car, it reset but will strike again if similar circumstances present. It could be any number (as in dozens) of things. I assume you were on a track at 138 mph so it could be heat related, air fuel issues, a failing sensor, motor issues, exhaust pressures, etc. etc.
You should pull the diagnostic trouble codes from the OBD2 port if you know how to use them and if you want to get a head start on your mechanic. Sometimes these things are very easy to diagnose and fix: sometimes not so much. Let us know how things go. GL
Old Jan 28, 2015 | 04:19 PM
cfpchfc1's Avatar
Thanks, I'll find out what happened
Old Jul 29, 2015 | 08:18 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
I know this is old thread, but I would like to know what was the issue.
VID997
97
Mar 20, 2018 02:23 PM
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
Saint Ari
Sep 7, 2015 07:09 PM
AuZZie
Sep 2, 2015 04:26 PM
