Options for reading the DME for overrun report
Old Mar 15, 2015 | 02:04 AM
deandob's Avatar
deandob is infamous around these parts
Hi,
Looking at purchasing a MY09 997TT cab but it is in a location with no Porsche dealer nearby to check the DME for overruns.
Is this something a performance shop or Eurocar maintenance shop can do? Or do I have to purchase the Durametric cable?
Alternatively as I will be buying a tune for the car, do any of the tuner options allow me to read the DME for overruns (saves buying a Durametric for a 1-off report, I can buy the tune up front).
Thanks.
Old Mar 15, 2015 | 05:00 AM
TheInfamousDrew's Avatar
TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !
Originally Posted by deandob
Hi,
Thanks.
I would honestly just buy a Durametric cable. They are worth every penny
If you can't wait for one to be shipped, you could call around to shops in the area to see if anyone has the ability to check.
Good luck!
Old Mar 15, 2015 | 05:38 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Hi,
Thanks.
Indy shops could do it if they have the tool.
On tunes...Softronic comes with Durametric cable and you can even upgrade it to the Pro version. I have had the tune for a while and has been awesome. You will want the Pro cable as the Enthusiast limits you to 3 VINs.
Good luck.
DC
Old Mar 15, 2015 | 06:02 AM
jhbrennan's Avatar
Good luck.
DC
Plus the Pro version allows you to do limited programming/coding of features.
Old Mar 15, 2015 | 06:29 AM
therock88's Avatar
YES!! Good point. I have the Pro, and it is very handy....
DC
Old Mar 15, 2015 | 06:59 AM
deandob's Avatar
Cool, thanks guys for the options.
Does Cobb's AccessSport read the DME overrev data?
Old Mar 15, 2015 | 09:41 AM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
We do not, but this is something we talked about adding from the very beginning.
Mitch
Old Mar 15, 2015 | 07:39 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
Wondering if it can be over written? Some say it can.
Old Mar 15, 2015 | 08:00 PM
therock88's Avatar
While nothing is impossible...The correct answer is "No", it cannot be overwritten or erased. At least not without detection and/or other issues. I believe there is a type of check-sum / validation byte, and if it was attempted and/or could be done, it would create a detection point, and/or error.
Again...nothing is impossible, but basically you cannot overwrite or delete under normal circumstances.
DC
Old Mar 17, 2015 | 04:06 AM
deandob's Avatar
I have the overrun report from the owner selling the '09 cab that I'm looking at purchasing, it is low miles 18K, 2nd owner (a lady) who has put most of the miles on the car. Here is the overrun report - what do you guys think?
Range 1: 681 (at 658 hours)
Range 2: 78 (at 658 hours)
Range 3: 9 (315 hours)
Range 4: 9 (315 hours)
Range 5: 8 (303 hours)
Range 6: 2 (303 hours)
current hours 682
The report from the dealer has the range 5 and 6 overrevs highlighted, I guess to show the owner the concern about them. The car is still under warranty and is obviously still OK as the overruns were 8K miles ago.
Is this anything to be concerned about, especially the range 5 & 6 (split second around 20mSec but over 9K revs!)? From reading other threads it says that engine damage is likely. Should I walk away from this one?
Old Mar 17, 2015 | 09:33 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
my opinion, those overrev counts are phantom computer garbage, not true over revs.
Old Mar 17, 2015 | 01:14 PM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
current hours 682
I freaked out over this for my -07, now almost three years later I realized that its just one thing to consider. If it had been over reved badly, it just wouldn't run well afterwards.
But use the report as a reason for haggling the price down
Old Mar 17, 2015 | 01:15 PM
therock88's Avatar
current hours 682
I would not be concerned with the Over rev report. The higher range (very minimal fraction of a second...if they even occurred) happened at 300 hours, which is 1/2 the total hours on the car...So if something was going to explode...it would have by now.
If you like the car, I would get it.
DC
Old Mar 17, 2015 | 02:32 PM
deandob's Avatar
Thanks guys. I agree it is probably phantom readings, as I can't see how the motor could be running at those revs for only 20 milliseconds or so - even the PDK can't change gears that quickly or the car slow down that quickly.
Old Mar 18, 2015 | 04:41 AM
Al Nunez's Avatar
Glitches for sure. And I have been saying it has to do with the 1.2 mm sensor adjustment at the flywheel. I have had it occur to my car which sits in the garage a large percentage. I don't drag my car, don't downshift to wrong gear, etc. it's a glitch period. Just like the coolant leaks, just another quirk these cars have.
