997.1 turbo slight rough idle at start up
Old May 3, 2015 | 06:23 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
When I start my car from cold, it idles a bit rough. Meaning the idle is not consistent at one RPM and vary +- 300rpms. In my past cars, I would clean the idle control valve along with all the intake components and would idle perfectly.
Do our cars come with an idle control valve? Or is there something I should address?
Old May 4, 2015 | 01:26 PM
Quadcammer's Avatar
Quadcammer is infamous around these parts
I get this a bit.
It typically starts at 1000rpm, bounces for about 5 seconds, and then evens out at 1100rpm until the SAI shuts off.
Old Jul 30, 2015 | 12:53 PM
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
I'm bumping this thread as I currently have the same symptoms on cold start-up. Any ideas? RPM's fluctuate +/- 200 until warm. I've cleaned maf, air filter, no boost leaks. Now what?
Old Jul 30, 2015 | 01:37 PM
XLR82XS's Avatar
Stock or tuned?
Old Jul 30, 2015 | 02:15 PM
Originally Posted by XLR82XS
Stock or tuned?
GIAC tune
Old Jul 30, 2015 | 07:32 PM
au2bahn's Avatar
In the process of changing plugs and coils now. Maybe it will help
Old Jul 30, 2015 | 08:56 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
It will help....Also consider cleaning around the plate in the throttle body...The plat that moves, gets gunked up around the edges, and stays stuck a little. I have found that cleaning that with some MAF cleaner, or Carb Cleaner helps.
Good luck.
DC
Old Jul 31, 2015 | 02:05 PM
au2bahn's Avatar
Good luck.
DC
Good. I already cleaned the throttle body plate, MAF etc.
Old Aug 2, 2015 | 12:03 PM
Macster's Avatar
Check your car's owners manual for any e-Gas calibration operation. AFAIK E-Gas systems require periodic calibration, which is done after a battery replacement but can be done at other times. Sometimes the tech will do this when the car in for service.
If the calibration operation is documented you should give this a try just to see if it helps. If it does then that's great. If it doesn't then at least you know.
Old Aug 2, 2015 | 12:19 PM
yah996's Avatar
yah996 is infamous around these partsyah996 is infamous around these parts
Hmm... I cleaned both MAFs and also the connector on the MAFs. It works in my case.
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
oddjob142
Aug 19, 2015 12:27 PM
