Minor fuel system upgrade (pump/etc?)
Old Jun 16, 2015 | 07:28 PM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
My fuel system is stock except for 1300cc injectors, but it can't quite keep up on E85. I need something to get me through the summer, as i intend to upgrade the whole system next winter when I do the short block.
From what I understand just dropping in better pumps is not easy due to the basket configuration...
So what about a single booster pump outside the tank? Or running a BAP or similar to the factory pumps? Anybody done either?
I am not a huge fan of either.. but since I just need a little bit more, for a little bit longer.. and the proEFI seems to handle FP loss well (cuts boost, etc if I set warnings) I think I can survive...
Old Jun 16, 2015 | 09:12 PM
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Check out silly rabbit. He's just finishing his basket/pump replacement for the 997
Old Jun 17, 2015 | 07:55 AM
i bought the silly rabbit stuff for my car but if you want a temporary solution i would give the BAP a try. i don't see why it wouldn't work well.
#TeamAIM
Old Jun 17, 2015 | 08:02 AM
I used on on my Z06. gave me 100rwhp more worth of fuel
Just looking at the SR stuff. Very nice.
Old Jun 17, 2015 | 02:35 PM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Not sure if applicable but in the N54 community several approaches was tested to upgrade the fuel pumps. The BAP just overdrives the pump and in the N54 case didnt help at all. Adding an inline pump worked quite ok and even if not as good as a replacement of the in-bucket pump still helped a lot.
Maybe adding an inline pump will keep you ok until you drop the engine for the build.
Old Jun 17, 2015 | 02:46 PM
weird.. with 19VDC+ to the pump, it should spin harder. Of course.. if they are trying to get pressure greater than the relief valve it might not help.
I used a BAP on my Z06 and gained +100rw of fuel.
SRM is really nice. Ill see what it is gonna take ($) to do half now half later. If its crazy, ill find a used BAP or a 3rd pump I guess.
Old Jun 17, 2015 | 03:03 PM
Originally Posted by xbox_fan
Not sure if applicable but in the N54 community several approaches was tested to upgrade the fuel pumps. The BAP just overdrives the pump and in the N54 case didnt help at all. Adding an inline pump worked quite ok and even if not as good as a replacement of the in-bucket pump still helped a lot. Maybe adding an inline pump will keep you ok until you drop the engine for the build.
N54 fuel system is nothing like 997.1. The high pressure system is the limiting factor there.
#TeamAIM
Old Jun 17, 2015 | 05:33 PM
Yea, just looked it up. N54 is DFI.. wont help if the low pressure system is at 19VDC
Old Jun 18, 2015 | 01:52 AM
xbox_fan's Avatar
Sure but I was only reffering to the low pressure side of things. The first bottle neck on the n54 was on the low pressure side.
HPFP upgrading is a separate topic...
Old Jun 18, 2015 | 09:37 AM
SamboTT@ByDesign's Avatar
I agree with Mark that the BAP may give you what you need here. I got you if you want the SRM though. The nice thing about the proper SRM upgrade is that you can expand on it later.
Old Jun 18, 2015 | 08:10 PM
problem is ill end up "wasting" 500$ on a dual BAP since we have two independent pumps, only to go SRM anyway next winter.
Back in college I rigged my alternator so that whenever the nitrous was active it raised the whole cars voltage to 16V. ha. It was funny you would see the dash/headlights/etc get a ****load brighter when it was active.
Cost about $1.
Old Jun 19, 2015 | 02:28 PM
yep thats true
#TeamAIM
Old Jun 19, 2015 | 07:27 PM
On It's way in a day or two bud. I will post up some packages and details soon guys!
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Superaudiofreak
Jun 10, 2016 02:04 PM
The Oss
Aug 24, 2015 08:19 PM
