noise after swa bar install
Old Jul 9, 2015 | 11:47 PM
kbhaw's Avatar
kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !
Hi guys,
Quick question, usually when you install aftermarket swaybars (installed GMG brand) is it noisy? I noticed more underchasis noise after the install of swaybars and my car shop installer told me it's from the aftermarket swaybars. Thanks in advance!
Old Jul 10, 2015 | 09:29 AM
TT Surgeon's Avatar
When I had Gmg sways front rear and it was dead silent.
Old Jul 10, 2015 | 12:15 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
I have Eibach brand....But have no issues/noise at all. Never heard that, so may check install?? I installed mine on my own.
Good luck,
DC
Old Jul 11, 2015 | 06:44 AM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
What type of links did you use? Did you all change to gt style mounts?
Old Jul 12, 2015 | 07:42 PM
kbhaw's Avatar
Good luck,
DC
Thanks for the replies! Maybe i need to reinspect where the noise is really coming from if that's the case
Old Jul 12, 2015 | 07:43 PM
kbhaw's Avatar
i believe the standard links was used. the ones included in my purchase, i didn't purchase any upgraded links but my installer said the stock bushings of my arms are worn out
Old Jul 12, 2015 | 10:29 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Had a similar issue with HR sway bars, ended up being the nuts on the links were not tight enough.
Old Jul 13, 2015 | 02:06 AM
kbhaw's Avatar
i will check thanks!
Old Jul 13, 2015 | 02:07 AM
kbhaw's Avatar
front stab links in the front is the ones from airrex kit and original in the back. is it from this?
BlackHorseTurbo
Apr 20, 2016 10:26 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
mlife2878
Aug 26, 2015 07:02 PM
Zero911
Aug 24, 2015 06:51 PM
