Changster's 997.2 TTS, pics mods etc
Thanks for the response, you definitely drive the streets harder than I do (what will pass in Taipei certainly won't here in NJ, USA...LOL). Your cold street tire pressures are what I set at the track in my Cup 2s! I run 34/37 cold for the street. Glad to hear that tire wear is quite even and there aren't any noticeable handling characteristics on the street with that set up.
I like your brief review of the Tractives, however I will likely start with TPC's front wide track kit to start. The "other bits", I was referring to were rear toe links. Looking forward to your review of the Tractives on the track. This has been very helpful. Thanks
I'm confused about this sump. Does your car not have the turbo Mezger dry sump engine?? Keep an eye on the shocks. One of our local guys has been running the Tractive shock set up for a little over a year and all 4 shocks are weeping heavily. Might be just bad luck but something to keep an eye on.
What do you mean by weeping heavily? Like it's leaking oil?
Before I bought the shocks one concern was reliability versus well known brands like JRZ, Ohlins etc. I definitely believe in Tractive's technology (DDA valving, etc) but they haven't been around long enough to build a track record on reliability yet. Knock on wood!
997.2 Turbo's/Turbo S's are the 9A1 engines not Mezger.
I'll report back on reliability of the shocks in due time.
And you're in NJ... lucky you. They're local.
Yes, I drove down to TPC in October last year. A great trip and awesome guys to talk shop with. That said, local is relative...they are in Maryland (a bit under 3 hrs away) but I guess that's pretty much local vs. coming from Taiwan!! Thanks again.
