30k service, now turbo's don't work?
Old Apr 30, 2016 | 09:19 AM
shahhm's Avatar
shahhm is infamous around these partsshahhm is infamous around these parts
hey guys, I'm looking for some advice on a problem I recently encountered with my 2010 997.2 Turbo.
I was up for my 30k service which I was told included the spark plugs changed out. Dealer said it would cost around $1700 which I thought was high so i took it to an aftermarket place here in Virginia Beach (Racewerks) who charged 1/3 of that. They have great reviews and are good people from what I can tell (even though I'm sure someone will respond and say "you get what you pay for")
In addition to the spark plugs, i had to get new tires and break pads on the rear tires.
Here's my BIG issues. Since getting the car back, the turbo's don't kick in. I can hear them spool up as if they are going to kick in like normal, but they never do. They just make a ton of noise. When I went to the boost gauge on the car, it looks as if it's going to increase but once the meter starts to read anything past 1 or 2 psi, it just goes all the way back down.
Has anyone had this happen before? think it's just a simple "connection" they didn't hook back up when they did the spark plugs?
Thanks in advance for your help. I don't know much about this stuff so I was looking for advice from the forum.
I did contact the shop but they are closed on weekends and so I'll have to wait till Monday to hear back.
Old Apr 30, 2016 | 09:29 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Boost leak most likely. Probably one of the lower hoses.Don't keep trying to boost it or you may blow a turbo from over spinning it.Look around and check all your hose connections.
Old Apr 30, 2016 | 09:32 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Boot hose wasn't reconnected. Should be a 5 minute fix. Bring it back for them to reconnect.
Old Apr 30, 2016 | 09:47 AM
shahhm's Avatar
Ok thanks guys.
Old Apr 30, 2016 | 10:00 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
As already said, you have a boost leak. The quick connect hoses are sneaky. They can seem appropriately engaged until you yank on them and then they pop loose. You may have to pull the rear bumper and all to get to the connections. A good tip is to lube the connector O rings with a tiny amount of oil. That makes sliding them all the way up into the female connector easy at which point the C clip will hold it in place correctly.
Old Apr 30, 2016 | 11:36 AM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
I had the same problem but the pipe came loose on the highway when I hit the gas hard. What I found was that the Y-Pipe came loose. You get the whooshing sound and but no boost. Mine came loose right after a 30k service also.
Old Apr 30, 2016 | 01:33 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Sounds like the mechanic didn't attached the actuator rod back in place. Like on passenger side maybe? Perhaps boost leak from hoses as mentioned above
Old May 1, 2016 | 11:26 AM
caslca's Avatar
caslca is infamous around these partscaslca is infamous around these parts
I had exact same thing. It was a hose which wasn't clamped properly. You can save yourself a trip and look under the car(no lift/jack needed) to see if the turbo->IC hose is connected on both sides. WHile there, you can also check the actuator arms on both sides and make sure they are attached.
ALso look under the hood at the two ends of the Y-pipe and make sure the hoses are well attached there
Old May 1, 2016 | 02:42 PM
Tareq's Avatar
Tareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant future
Same thing happend to me, +1 on the actuator rod not being reconnecting, mine wasn't.
However checking the hoses won't take you long and can be done at home. Both sides of the Y-pipe in the engine bay and Y-pipe to throttle body. Then boost hoses from turbos to Intercoolers under the car.
Old May 1, 2016 | 08:14 PM
jhbrennan's Avatar
I'm surprised (maybe not) that the service techs don't take a test ride after service to see if everything works.
Old May 2, 2016 | 01:01 PM
997TTEQNY's Avatar
997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future
^ this
Old May 5, 2016 | 08:42 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
I assume you got this issue resolved OP?
Old May 14, 2016 | 04:51 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
As everyone said boost leak for sure, take a look at where the hoses connects directly to the turbos. To replace the most forward plugs (closest to front of car) these hoses had to be disconnected. The clamps must be extremely tight otherwise on the first real boost build they tend to pop off. You may be able to see this by looking underneath the car.
cl600bill
Bentley
14
Jan 24, 2023 08:58 AM
flewis763
Jun 25, 2016 05:54 AM
SinisterSF
Apr 29, 2016 07:34 AM
changster
Mar 27, 2016 08:01 PM
Polar993
Mar 24, 2016 01:04 PM
