Quickjack 7000SLX
Old Jul 6, 2016 | 04:41 PM
  #61
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Based on my curiosity, I did several test. Since the wife's car was too wide, I couldn't drive up with the two wheels on one lift so I drove up on the two together in parallel. From a dead drop, no go with car weight. It definitely needs 1 inches of upward movement before lifting vehicle weight. These barely fit underneath my lowered car with an inch or less clearance between the block and lift points and lifted the car with no issues. Name:  image-2025754817.jpg
Size:  455.7 KB Perhaps if anyone needs to drop below the last locking point, they can weld an additional locking bar on the tray.
Old Jul 6, 2016 | 06:19 PM
  #62
Marpir821's Avatar
Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !Marpir821 Is a GOD !
Problem is, if you weld an new locking point, still no gurantee it can get itself up from there. As they told me, below the first locking point...it starts losing stregnth rapidly.
PS...now put coil overs on and TechArt side skirts and then getting it under there is quite a challenge.
Old Jul 6, 2016 | 07:08 PM
  #63
au2bahn's Avatar
I believe it can. I went pretty low way past the first locks to approximately 6" to dead drop and stopped. Then went back up
Old Jul 6, 2016 | 07:20 PM
  #64
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Thanks for testing
Old Jul 7, 2016 | 04:28 AM
  #65
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Definitely disappointing
Old Jul 7, 2016 | 03:28 PM
  #66
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
My ezcarlift.com will raise from zero but it is using a screw drive and not hydro. Nothing to fail but the welds. Again, not for everyone because of the weight limit but awesome for the 911.
Old Jul 8, 2016 | 01:51 PM
  #67
turboslut's Avatar
Do you think there is enough heigh clearance (with suv adapters) to drop the engine onto a table jack?
Old Jul 8, 2016 | 04:05 PM
  #68
au2bahn's Avatar
Yes definitely. Main reason I got it with the Adaptors. Someone with a 996TT on one of the forums has done it. You have to initially raise it and set on race ramps, then continue with additional height either the adapters
Old Jan 16, 2017 | 08:40 PM
  #69
kenbelt's Avatar
kenbelt is infamous around these parts
Thanks for posting...the exact lift I need!
Old Jan 17, 2017 | 08:42 AM
  #70
function12's Avatar
If you need floor protector or any other accessories. Order them now because shipping will kill you.
Old Jan 17, 2017 | 12:19 PM
  #71
DoDaLeCa's Avatar
DoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud ofDoDaLeCa has much to be proud of
The apparent short span between lift points on the EZcarlift scares me from a previous incident I witnessed (probably my paranoia if it's using all four lift jack points if that's what those locations are designed for).
When working at a major auto repair shop I saw one of the tire bay guys lift up a VW vanagon for 4 new tire installs. When he took off the two front wheels first the van rotated over backwards falling off the lift due to the engine being behind the rear axle.
Old Jan 17, 2017 | 12:26 PM
  #72
function12's Avatar
You can lift from wherever you want on the side frame rails. Lifting points slide on the lift rails. I use their magnetic pucks that go into the side jack point locations. Same spot the dealer uses to lift my car.
That being said you always want to lift the car to the lowest point you need. No need to be 2 foot in the air to change tires.
Old Mar 21, 2017 | 08:39 PM
  #73
8202632's Avatar
8202632 is infamous around these parts
Originally Posted by Marpir821
Yes, although my wifes Cayenne GTS is like 5600lbs and my 5000 QJ lifts it fine.
How are u using it on your cayenne? I tried and the jack points seem too far apart?
Old Mar 24, 2017 | 09:24 AM
  #74
4LUX's Avatar
4LUX is infamous around these parts
I just picked up a QJ BL5000XL off of Craig's list for less than half price. It will come in handy, having two P car to work on!!!!!
Old Mar 24, 2017 | 12:03 PM
  #75
HardHitter's Avatar
HardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to all
$800ish? I've been looking for one. One on ebay just went for $1300. If you got it for half off, great grab!
