Cobb install location
Old Jul 10, 2016 | 01:54 PM
hatnlvr's Avatar
hatnlvr is a jewel in the roughhatnlvr is a jewel in the roughhatnlvr is a jewel in the roughhatnlvr is a jewel in the rough
Hi guys,
For those of you using the Cobb tune, where are you guys mounting the accessport? I'm having a hard time deciding where to mount it, anyone with install pics would be much appreciated.
Old Jul 10, 2016 | 04:01 PM
Slate997TT's Avatar
Slate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant future
Glove box
Old Jul 10, 2016 | 04:03 PM
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
There's no need to mount it,... unless you plan to leave it in there long-term to use as a gauge.
I did my Stage 2 flash and removed it before pulling out of the garage.
This year I had a custom tune done,.. and as a result,.. I had it in there for a few weeks while as I was pulling data-logs and such.
Even then I just left it on the passenger seat. I'd shift into third before doing a pull,.. then pick up the Accesport and press the logging button,... then floor it. When it got to 7,000 rpm I'd press it again as I clutched in,.... click the trans into 5th and toss the Accesport back onto the passenger seat.
Now that my tune is finalized,... it's back in the box.
Here's the pictures Accesport has on the web.
(I'm diggin' that radio. I wonder if it's possible to switch to that?)
Old Jul 10, 2016 | 04:29 PM
hatnlvr's Avatar
Thanks for the reply. I was figuring mounting it for logging would make it easier (I'm doing the passenger seat method now LOL), maybe I can find a suction cup windshield mount for temporary mounting.
Old Jul 10, 2016 | 05:32 PM
Boosted TTS's Avatar
Boosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond reputeBoosted TTS has a reputation beyond repute
Glove box.
Old Jul 10, 2016 | 07:41 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Originally Posted by Duckstu
There's no need to mount it,... unless you plan to leave it in there long-term to use as a gauge. I did my Stage 2 flash and removed it before pulling out of the garage. This year I had a custom tune done,.. and as a result,.. I had it in there for a few weeks while as I was pulling data-logs and such. Even then I just left it on the passenger seat. I'd shift into third before doing a pull,.. then pick up the Accesport and press the logging button,... then floor it. When it got to 7,000 rpm I'd press it again as I clutched in,.... click the trans into 5th and toss the Accesport back onto the passenger seat. Now that my tune is finalized,... it's back in the box. Here's the pictures Accesport has on the web. (I'm diggin' that radio. I wonder if it's possible to switch to that?)
Radio? We must be the same age or maybe older . But I agree . What tape deck is that? I want one
Old Jul 11, 2016 | 03:30 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
I got a vent mount and stick it in the left vent when I do logging. otherwise glovebox.
Old Jul 11, 2016 | 04:10 PM
SamboTT@ByDesign's Avatar
Hey y'all! I realize most here are my peeps including the OP!
Yeah I think he is looking for opinions on mounting for the purpose of a gauge and real time data. Suction cup mount may be the best because you can move it around. I like it on the left above the headlight switch in that little space between the pillar and cluster.
Old Jul 11, 2016 | 04:20 PM
hatnlvr's Avatar
This might be a good option
Old Jul 11, 2016 | 04:25 PM
Duckstu's Avatar
What's your favorite solution for that?
I'd perhaps like it to monitor IAT's. Really I'd like an analog gauge for that,.. but the AP I already have.
Old Jul 11, 2016 | 04:37 PM
hatnlvr's Avatar
Thanks for chiming in Sam
Old Jul 11, 2016 | 05:14 PM
Cheers,
Less is more in this case so you can see it although you can display up to 6 units and the shift light!
So:
- Boost and IAT
- Boost, IAT and two cyl of timing ratard
Assuming you have a good/set tune the rest is safe and automatic. With the above you can see if the car is running tip/top and not leaking or being pushed beyond octane/hardware limits at any given moment. You get to know the car and tune in many settings rather than one or two logs. Sometimes you can real-time verify "feel" to #'s
Old Jul 11, 2016 | 08:47 PM
DOOBEE's Avatar
DOOBEE is infamous around these partsDOOBEE is infamous around these parts
I use a flexible phone mount plugged into the passenger footwell socket. Plugged in all the time except for today to download some logs.
Old Jul 12, 2016 | 04:26 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Dr.Disaster
Bentley
56
May 22, 2020 12:51 AM
Chris_FL
Jun 29, 2016 03:23 PM
bobolouie
Apr 27, 2016 08:38 AM
louisifis
Apr 23, 2016 04:23 PM
