How many labor hours for clutch replacement (997.1 Turbo)
Old Jul 27, 2016 | 08:06 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
How many labor hours for clutch replacement on a 997.1 Turbo? I'm getting some insane variations from different mechanic shops with the Porsche dealership being the cheapest by far!
Porsche of Hawaii quoted me $160/hr x 8-10 labor hours,
first indy shop quoted me $180/hr! x 16-18,
second quoted me $125/hr x 14
Old Jul 27, 2016 | 10:44 PM
echerbst's Avatar
echerbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond reputeecherbst has a reputation beyond repute
I charge 10 hours do just a clutch. Anything more is robbery. Dealer is being fair at 8-10.
Old Jul 28, 2016 | 12:58 PM
Macster's Avatar
FWIW a while back -- over a year ago, err make that around (or over) 2 years ago -- i had my 996 Turbo in for a new RMS. While the clutch wasn't renewed the flywheel had to be removed to get at the RMS and of course the old RMS removed and the new one installed.
The dealer charged me around $1700. The dealer's labor rate was $150/hour at that time and the bulk of that $1700 was labor. Assuming it all was that's approx. 11 hours labor to drop the tranny and remove the clutch hardware, including the flywheel, then put the car back together again.
Might add that even though the clutch was fine, the disc had no measurable wear even at 120K+ miles, the tech did replace the needle bearings of the clutch control shaft. These get replaced every time the tranny is out even if the rest of the clutch hardware is fine.
My point in highlighting this is the tech told getting the bearings out and the new ones in is a "fiddly" job which adds to the time it takes to R&R the tranny.
Thus I think thePorsche of Hawaii quote of 8 to 10 labor hours is I think a realistic quote for your car's clutch job labor cost.
Old Jul 28, 2016 | 07:23 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Originally Posted by AutoTalent
We charge 9 hours at $125 per hour.
^^This price is pretty good! Average is 12 hours at $130
Where are you guys located ? Ha
Old Jul 29, 2016 | 10:16 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
It depends, but 8-12 hours.
Plan on spending from $ 80 to $ 120 p/hour, again, depending who does the work.
Old Jul 29, 2016 | 11:13 AM
kchu221's Avatar
kchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond repute
Theyre located in Los Angeles, CA. right next to the LAX airport, theyre the only guys that touch my car, all the mechanics there are top notch.
Old Jul 30, 2016 | 07:11 AM
32krazy!'s Avatar
obviously being located on an island your limited to who can do the work. this drives the shop rate not the hrs to do the work. the second quote is likely with an engine drop which porsche manual says is needed. most dont do that so 8 hrs saved.
unless your able to get the car stateside your best bet would be the dealer and know you also have warrenty with the work. ( i cant believe i just suggested using a dealer!!!!!)
Old Mar 29, 2018 | 07:54 PM
msand9898's Avatar
msand9898 is infamous around these parts
Sorry to bring this thread back, but what should be a fair price to pay if my engine and tranny are already removed and I then decide to supply shop with the Sachs clutch and plate to replace?
Old Apr 17, 2018 | 05:17 PM
icarp's Avatar
icarp is infamous around these parts
2 hours with cleaning the bell housing and surrounding areas
a really good tech can do a clutch on his own car in less than 4 hours
airbusdrvr
Apr 5, 2022 11:56 PM
dgreen78
Apr 30, 2016 07:18 AM
jjurroz
Mar 28, 2016 11:52 AM
