Video: Bolt-on 997.2 takes on monster-builds at NoFlyZone California 1/2 Mile Event
Originally Posted by pdxm5
Part of it is funny the other part is that some newb will read it and believe it.
How is anything posted not believable as i not only post all vids vbox and timeslips, I also have people in my car during runs who can vouch and forum members and Porsche builders on the other side of my races. You think this is all some conspiracy where I'm making fake vboxs fake timeslips and paying people to lose races against me? Lmao.
I believe you bro!
Take forums with a pinch of salt!
+1
I'll come document it if Adam likes. Boost should shows on the dash when launch control is active without launching right?
1 camera phone is worth 1000 words
I'm not trying to add fuel to the fire here, but, my data logs AS I UNDERSTAND shows my car launches at 23psi boost... unless I'm not understanding the dynamics of what's happening I can absolutely believe Adam's car launches at 30 psi boost.
With all due respect (me not knowing who you are) can you please explain why you don't think it's possible for these cars to launch with so much boost pressure? I'd love to be educated on the subject.
there are many reasons. There are a few good write ups on how botl works on most cars I am on my phone and don't have the links. The majority of cars 500-2000hp will leave at like 3-7psi. There is a way to make a ton of botl by retarding the timing by like 60% and sure you can see a spike of 30psi but your not at that pressure actually putting power down. The little factory vtgs won't sustain 30psi on top of that. Is it possible to see 30psi on the gauge? Maybe, but it's incorrect to state that a 997.2 with factory vtgs is leaving the line and actually seeing 30psi at normal timing.
in big hp diesel trucks we leave at 30psi or alot more if the brakes and suspension can hold. some cut 1.30 60ft times in 5000lb trucks. my 8000lb truck leaves at 28psi and cut's 1.60's all day long .
this was an old truck about 5 years ago . 25psi launch .
this truck leaves at over 40psi .
this truck leaves about 28-32 psi depending on the track. ( the green ford )
Not sure why your stuck on this...
Not really fair putting words in his mouth.
He didn't say how much power it's making at that point either.
He just said that's what's on the gauge at launch.
Obviously his car is making good power. We all watched the same videos.
The proof is in the puddin
The stock ECU on a 997.2 targets 23.2 PSIA on a bone stock car. Remember this is absolute so if you were measure it gauge, subtract ambient pressure. This is around 8.5PSIG at sealevel.
If someone has changed the launch control target PSI then it is possible for the car to be at 30PSIA.
Thanks,
Mitch
Thanks,
Mitch
Mitch, yeah ive seen a bunch of logs from stock 997 all the way to stage4 991 cars. Long clearly stated 30 PSI several times not PSIA.
30psi = 44.7psia
15psi is very doable, but he claims its double that. Would love to see his logs.
30psi = 44.7psia
Interesting that you've seen logs of stage 4 991's. What psi to they leave at? I have one so I can see if you are correct. By the way it leaves at a lower psi than my 997.2 despite my 997.2 having factory original stock turbos and my 991 having Tial 68 VTGs with the HTZ wheel.
While my 997.2 makes more peak boost than my 991, they are very different power curves. The 991 hits mid-20's and stays there to redline (tapering very slightly). The 997.2 hits 30+psi and sustains it for a short while and then tapers quickly down to 16-17 at 7K rpm.
long, its really as simple as posting a log from you car i am sure i am not the only one that wants to know how your getting so much boost off the line. all the 991s ive seen have been below 12psi.
