Question regarding boost loss shortly after installing Cobb stage 2.
Old Apr 8, 2017 | 08:55 AM
09997TT's Avatar
09997TT is infamous around these parts
Thinking the extra boost might have pushed something off?
I have fabspeed cold air intake and speedtech 3.0 X-Pipe running cobb stage 2 on 93 octane and just yesterday noticed boost levels building up to max and then dropping and coming back up just to drop again. It would seem I am losing pressure somewhere. I have checked the ends of the y-pipe and everything seems in order there (all seems tight); it is a 997.1 Turbo, does anyone have thoughts on what I should check next to see where my pressure loss is coming from or should I bite the bullet and buy a pressure test kit and go from there?
Thanks guys!
Old Apr 8, 2017 | 09:24 AM
HotRodGuy's Avatar
Pressure test kit is essential for any turbo owner.
Old Apr 8, 2017 | 10:26 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
There are a few spots it could leak like that. sounds like a clamp letting go at full boost. try checking the plenum clamps. You will need a long screwdriver and a flashlight.Then the y pipe. If all the clamps are tight and hoses are on flush you will need to do like hotrod said and pressure test.
Old Apr 8, 2017 | 12:07 PM
SamboTT@ByDesign's Avatar
Thanks for reaching out J. Hopefully with some logging next week we can find a few answers and I'll do my best to help you sort it out.
Old Apr 8, 2017 | 02:00 PM
09997TT's Avatar
Thanks fellas! Will check all that this weekend and get some logs to Sam.
Old Apr 13, 2017 | 01:44 AM
mavila's Avatar
mavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of light
Has anyone ever installed a true analog boost gauge in the car? I'd really like to do this as I start down the path of modding the car, as I want to see a real-time boost pattern - not an interpretation through the ECU. I'm curious as to the best place to tap into and where to route the line through the firewall into the cabin.
Old Apr 13, 2017 | 09:53 PM
Southpaw07's Avatar
5 Year Member
Southpaw07 is a jewel in the roughSouthpaw07 is a jewel in the roughSouthpaw07 is a jewel in the rough
Replacing the sport chrono dial with an analog boost gauge would be nice.
Old Apr 13, 2017 | 10:29 PM
longboarder's Avatar
My coolingmist meth controller which sits perfectly in the Sport/Chrono pod is also a boost guage.
Old Apr 15, 2017 | 01:11 AM
mavila's Avatar
Nice, clean install. I wouldn't want to screw up my interior so would probably just mount the gauge to the steering column. Where did you tap into for the boost measurement?
Old Apr 15, 2017 | 10:00 AM
At the Y pipe near where it connects to the plenum. At that location boost reads maybe 2psi higher than the stock boost reading.
Old Apr 15, 2017 | 10:53 PM
bigrpowr's Avatar
bigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nice
usually that would indicate pre-intercooler reading vs. post . not sure what kinda pressure drop there is across the coolers but it's prolly close to 2psi . stock reading would probably be an accurate post cooler reading.
Old Apr 15, 2017 | 11:50 PM
mavila's Avatar
Is there really a 2 psi drop across the intercoolers? That seems pretty large, although my past experience is with a single IC car (3rd gen RX-7). And is the stock reading taken post-intercooler?
I also realized my previous post may have come across poorly. I didn't mean that I thought longboarder's interior looked screwed up. I just meant that if I tried to take apart my dash to do something like that, I'd probably screw mine up.
Old Apr 16, 2017 | 07:28 AM
Guys my coolingmist meth/boost guage reads boost post intercooler it's right here where the Y meets the plenum. Not sure where the stock boost reading is taken. Anyway I can look at both readings at the same time and my coolingmist guage registers Boost a little sooner hence the 2psi or so differnce.
