Anyone using or have experience with an HKS EVC6-IR boost controller?
Old May 2, 2017 | 08:29 PM
santon997's Avatar
santon997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant future
Having issues getting psi up and convinced it's a setting. Stuck at 20 psi. HKS has no tech support number. Wondering if anyone is using this or knows someone who can walk me through the basic settings. Have tried everything.
Old May 2, 2017 | 08:51 PM
santon997's Avatar
This is on an AMS full Alpha 9 kit.
Old May 3, 2017 | 02:37 AM
gofast's Avatar
gofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud of
I don't have my car with me and haven't used it in a while.
From what I can remember, during set up, you need to do a test pull to get the base waste gate spring pressure first and set it.
Then you set target pressure in column A, B or C and there is another setting for the aggressiveness of building boost, I can't remember if this is done with a percentage... I think mine was 8-10. It was a pretty easy set up tbh. Much easier than the Greddy I was using before.
What is your target boost?
Remember when setting up a boost controller try and run race fuel for safety incase you over boost.
Old May 3, 2017 | 04:38 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
There was a bug in the HKS software.
If you set STD MAX BOOST and TARGET BOOST same in the settings you cant boost as you want.
I'm using EVC since 2005, if you can post pics of your settings pages i can help you out
Old May 3, 2017 | 04:48 AM
santon997's Avatar
Awesome thanks guys. Will post them this afternoon when I go and get car,I read that about setting those the same and the issues it creates. Car made 625 to the tires at 20 psi and trying to get to its full potential. Emre Iwas actually at Magnus tuning it and was talking to Marco and Matt about reaching out to you as I am sure a tranny is in order in the near future as car is a tip.
Old May 3, 2017 | 08:41 AM
santon997's Avatar
Below are screen shots.
ID:	475607   Click image for larger version
ID:	475608   Click image for larger version
ID:	475609   Click image for larger version
Old May 3, 2017 | 08:48 AM
Haha, good coincidence!
Settings seemed fine to me;
Did you calibrate throttle correctly? Do you see %99-100 when you are on boost?
If you didnt set it up correctly and have boost compensation by Throttle,
it wont let you boost as you want.
Other things to check step by step;
- Make a boost leak test
- Check EVC vacuum/boost lines, make sure you dont have any leak there.
- Check WG's by hand vacuum/pressure tool, to make sure they operate correctly
Old May 3, 2017 | 08:52 AM
santon997's Avatar
Throttle is hooked up properly you can see the open and close percentages with the motor off but ignition on. Seems fine. Waste gates under pressure with gauges on them start to crack at 14.5 psi. What should my standard max boost be set up as as well as the initial offset?
Old May 3, 2017 | 08:55 AM
santon997's Avatar
Throttle parameters with pedal not touched and pedal to floor with ignition power on motor not running.
ID:	475612   Click image for larger version
Old May 3, 2017 | 08:58 AM
Make STD MAX BOOST 13.5 or 14 and try again.
Leave the OFFSETs as it is now. you can use that later on for fine tuning.
Old May 3, 2017 | 04:23 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Silly question: Are you sure its on?
If you dont see the "A-B-C " on top its running spring pressure ... Longpress the upper two buttons to turn it on/off and cycle through with the second button ...
Old May 3, 2017 | 04:49 PM
santon997's Avatar
We actually ended up figuring it out. We set the throttle setting with the car off like the manual said. However with the car running the no throttle position( the starting point) dropped by 150 value. So we reset the throttle to accommodate for that and we instantly made 25lbs of boost. Then we started playing around with the efficiency at like 80-90 percent to to get it to peak at our max boost variable. We were able to get it down but was still overshooting by like 1-2 psi. Next week have dyno timed book so will finalize it on there. Thanks guys. Big difference between 20psi and 25
ID:	475646   Click image for larger version
Old May 4, 2017 | 07:37 AM
25psi is a lot of boost for stock rods
#TeamAIM
Old May 4, 2017 | 07:51 AM
santon997's Avatar
That was the inaugural pass when we got it going. Dropped it to 22-23 after that. Will wrap it up on dyno next week in that range.
Old May 19, 2018 | 01:37 PM
The Bogg's Avatar
I'm just in the process of setting up the same HKS EVC 6 2.4IR boost controller, any new tips appreciated!
