Sachs 2.5 clutch still the popular set up?
Old May 17, 2017 | 09:50 PM
Don N.'s Avatar
Don N. is infamous around these parts
From what I have researched, it seems like the Sachs "2.5" clutch kit that uses the 997 GT3RS 4.0 disk along side with the sachs 487 pressure plate is the popular set up to go with?
I am looking at putting down around 650-700 whp, which seems like its right around the threshold of that clutch. Anyone with experiences on this set up with those power levels or greater that you can provide any input or further suggestions?
thanks!
Old May 17, 2017 | 11:08 PM
SidePieceRacing's Avatar
SidePieceRacing is infamous around these partsSidePieceRacing is infamous around these parts
Im running Sachs 2.5 in my awe 750 equipped 997.1tt
Old May 17, 2017 | 11:14 PM
SamboTT@ByDesign's Avatar
Hi Don. It's a great set up and can be configured several ways with different flywheels and disks. Feel free to reach out and I can help you with pricing and support to get you into the right set up. In stock and ready to ship. Do you have your power kit sorted already?
Old May 18, 2017 | 09:30 AM
austx911's Avatar
5 Year Member
austx911 is infamous around these partsaustx911 is infamous around these parts
I'm wondering why BL didn't install a similar combo in my car. Similar power levels - 650-700wtq. They initially installed a GT2 clutch which slipped after I got the car back. GT2 clutch is good for 650tq at the motor right? I questioned the use of this clutch before the work was done and I was assured it would work fine. They ended up replacing it with a Sachs twin-disk variant. It doesn't slip but pretty heavy and a little grabby. How would that compare to the clutch mentioned above?
Old May 18, 2017 | 09:42 AM
rob.boost's Avatar
rob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond repute
I received my clutch from Sam and it worked great until I put Alpha 30's on the car around 23-24psi. Such a great clutch, so close to stock it is insane.
Then I just took that clutch and changed it to the Proto Twin setup, which has the exact same feel. I couldn't be any happier!
BTW, can't say enough about Sam, he is the man.
Old May 18, 2017 | 10:55 AM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
I did the 2.5 with the BBI slave, and I gotta tell you it's one of the heaviest clutches I've ever had in a car - I wish I had kept the OEM slave configuration - but the engagement is great and consistent.
Old May 18, 2017 | 12:17 PM
rob.boost's Avatar
I can understand why people go with the GT2 type slave setup, and get rid of all of that extra crap that can go bad... From the slave / master, to the accumulator.. But I have to say I am willing to pay the extra to keep the stock assist... Sure you don't get the "feel", but for stop and go traffic, and ease of driving I love it.
Old May 18, 2017 | 02:30 PM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
using the Sachs setup I got from Sam with my OEM slave setup, works great. Holds all the power and drives like a stock clutch in my opinion.
Old May 18, 2017 | 08:55 PM
trbofvr's Avatar
trbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud of
How many have actually had the stock assist setup fail? Is this a sure thing after some mileage or just a case here and there sort of thing?
Old May 18, 2017 | 09:26 PM
pdxm5's Avatar
pdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond reputepdxm5 has a reputation beyond repute
I was all against heavier gt2 style assist until I actually did it. Took me 1 day to get used to it. Can sit in traffic all day and not really care, left leg got used to it and it feels great.
Old May 19, 2017 | 02:44 AM
Nate Tempest's Avatar
Nate Tempest is infamous around these parts
Is this with the assist spring switched for a GT3 one, or still the stock turbo spring? Everyone seems to say that with the GT3 spring it's certainly stiffer but not unbearable, whereas if you keep the Turbo spring, it.. basically is unbearable.
Old May 19, 2017 | 07:25 AM
zmw's Avatar
zmw
That's a great question... I don't actually know, I'll have to look at my parts list. Unless the BBI slave came WITH the new spring setup, I doubt we replaced it. We had the motor out and were doing a bunch of other stuff but I don't remember discussing this at all.
-Z
Old May 19, 2017 | 09:33 AM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
I don't think the BBi kit comes with a new assist spring. You should buy a GT3 one. It makes a noticeable difference over the stock turbo spring and massive difference over no spring. I bought mine from Paramount for $75 shipped. Here is the part number with a clickable link to their page 997-423-081-06
The 997 GT2, GT3, GT3RS clutch assist spring is the same - I think Porsche kept it the same for their 911s that didn't use the accumulator-style setup the TT has.
Also, I have a Sachs "2.5" setup along with the EVOMS GT2 slave conversion, so mine might be a touch more stiff than a conversion with a stock clutch setup.
Old May 20, 2017 | 01:41 PM
Don N.'s Avatar
How much power were you running through your clutch?
Old May 20, 2017 | 03:09 PM
M3 Maestro's Avatar
Nothing crazy. Makes around 700whp. Has upgraded vtgs. Plenty of info on my build thread. I would use something different for more power but for most bolt on cars this seems to be the best bet.
