Xonas are on!
Old May 17, 2018 | 09:27 PM
  #31
The Bogg's Avatar
Originally Posted by A418t81
Great first impressions. Back in the day when I used boost controllers I was big into the Profec B and subsequently the Profec Type S, Lol. Haven’t thought about those in at least a decade.
It looks like boost controllers have come a long way with fancy displays and settings compared to the pushbutton mechanical systems of the past. I've never used one before. Technically I still haven't used one, lol. I'll read the manual soon.
Old May 18, 2018 | 05:41 AM
  #32
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
Boost controllers have come a long long way from when I started playing with this stuff. Electronics in general have.
Here are some of the boost controllers I have used:
Greddy profec and profec b (multiple vintages)
HKS evc (multiple vintages)
Apex AVC-R (multiple vintages)
Manual boost controllers of all kinds
In my teenage years (pull the wgt hose off, plastic tees, mig welding tips, bending wgt rods,weld wgt shut,etc) the good old days full of pinging, fuel cuts, and shenanigans
Yup I'm that old lol
Not having access to boost control is a new one for me and drives me nuts lol. One of the reasons I would to move from vtg
Old May 18, 2018 | 11:44 AM
  #33
The Bogg's Avatar
Just a quick update - finally getting a taste of what these babies can do. Man they spool up really quickly. I'll compare logs with my 68s but I'd say subjectively they spool up even quicker. I know that spool was one of my big concerns with aftermarket turbos on this car. Sorting through a few issues but making good progress. Couple of 2nd and 3rd gear pulls were really good.
Old May 18, 2018 | 07:25 PM
  #34
The Bogg's Avatar
Originally Posted by TT.BRN
Congrats, remember you promised pics, lots ....
Hope you kept the HKS's manual, so many things those buttons do ... Longpress upper two will turn it on/off, second button cycles maps (longpress saves current setting/map as default/startup condition), 3rd button brightness longpress resets PH value, other combos cant recall right now ....
When I longpress the upper 2 the unit doesn't physically power down. According to the manual, if the letters A B and C aren't at the top of the display then it is in bypass mode and operates on wastegate pressure. Is this what you remember?
Old May 18, 2018 | 07:30 PM
  #35
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Yea exactly when there are no (A B C) then it's off (gate pressure) ...
Old May 19, 2018 | 09:02 AM
  #36
The Bogg's Avatar
I'm not sure what gate pressure is but the boost reading in "bypass" is pretty high according to the Cobb datalogs. Peaking at 21psi I think. The reading on the HKS is lower. Not sure who is right, lol. I will try turning on the boost controller now and fine tune it.
Did a 75-110mph 4th gear pull in 3.7s with ZERO knock sensor activity. This is the same time I got on my Champion 68s with a little knock sensor activity iirc. The new intercoolers are incredible, hardly any rise in the intake temps on the pulls so far. I would have liked to try these coolers with the 68s but obviously it didn't happen.
Old May 19, 2018 | 09:04 AM
  #37
The Bogg's Avatar
This is my first car with bovs - I can't believe how audible the "whoosh" is everytime you transition from on boost to off boost, even with the window open, car loud, and going fast. And the bovs are at the back of the car on the intercoolers. Sounds cool though.
Old May 19, 2018 | 09:35 AM
  #38
M3 Maestro's Avatar
Bogg where is the HKS pulling its pressure reading from? If it's on the intake manifold it will be lower because of any losses across the throttle body. If it's in the y pipe like the factory sensor it should match pretty closely. And of course before the intercoolers it would read higher since it's before the intercooler loss etc,.
Good luck
Old May 19, 2018 | 02:33 PM
  #39
The Bogg's Avatar
I believe it comes from the compressor housing? Here's the diagram from the manual, I think this is how it was hooked up. At least it was supposed to be this way, lol.
Old May 19, 2018 | 02:36 PM
  #40
The Bogg's Avatar
It does show vacuum in the display so I'm not sure if it reads from the line on the intake plenum which is the same line as the fpr. But I didn't think that was a pressurized line, otherwise the fpr reference line would blow off!
Old May 19, 2018 | 02:49 PM
  #41
The Bogg's Avatar
Thanks Sam! Happy with it. Just having difficulty understanding why on wastegate pressure alone there is so much boost??? And if the HKS is reading on the same side of the throttle body then I don't get why it's reading different from the stock pressure sensor. Purely academic but it makes me wonder if there was an error in installation/plumbing. I will check with my shop to confirm that it was installed like the pic shows...
Old May 19, 2018 | 03:21 PM
  #42
M3 Maestro's Avatar
If you read boost and vacuum you are reading after the throttle body
The higher boost on just wastegate could be the actuator preload. Dunno where TiAL sets those. Did the shop discount those and retighten them etc. Lots of reasons.
Old May 19, 2018 | 04:47 PM
  #43
The Bogg's Avatar
The shop didn't do anything with the wastegates other than hook them up. The Cobb reads boost and vacuum but as far as I know, the values for vacuum must just be modelled since there's no sensor after the tb. The HKS wouldn't be modelling anything, it must be getting a true reading, otherwise it would suck lol.
It's no biggie if the wastegates are just tight because in the 3-4.5k rpm range the boost is 21psi or less which should be "safe" and probably close to where we would be targeting it anyway I'm guessing.
Old May 19, 2018 | 04:50 PM
  #44
The Bogg's Avatar
As I look at the logs I see that at some point the throttle angle changes even though I've got the pedal mashed to the floor. The boost stays solid throughout without any erratic shifts. Is the car "smart" enough to adjust the throttle angle mechanically to stay within parameter targets? for example, if the boost was climbing too much and the target "load" was exceeded would the car close the throttle incrementally?
With the vtgs the car could command the vanes to open if boost was too high but I wondered what would happen if a non-vtg car boosted beyond target parameters. If I'm understanding it correctly, the car does react...
On the first couple of tune revisions the throttle body would abruptly slam shut. Looking at other threads I believe it's something to do with the ASR tables for early 2007 cars having to be adjusted.
Anyway, off to fiddle with the boost controller!
Old May 19, 2018 | 09:23 PM
  #45
whats the boost do when the boost controller is off? that's how you can check where the gates are set. normally Xona Alphas will be set to 1 or 1.1 bar.
HKS has some offset settings that are tricky to get right. I wouldn't use the TPS modeling function of the HKS and only use the RPM function. First start with setting A and keep it simple raising the boost flat until you reach your desired torque MAX, then switch to setting B and start from value in A. Raising boost with RPM after the TQ peak to keep the HP climbing while holding TQ in check.
You'll have to get comfortable with the HKS because boost control is now on you.
#TeamAIM
