Sponsored by: Bears Transport
997.1 what is this beeping ;)
Old 05-17-2018, 06:43 PM
santon997's Avatar
santon997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant futuresanton997 has a brilliant future
Old 05-18-2018, 04:44 AM
The Bogg's Avatar
no idea what the beeping is, maybe the boost controller? I can't wait till my car accelerates like that!
Old 05-18-2018, 06:24 AM
santon997's Avatar
Thought that as well or the aeroforce gauge but cannot pinpoint where it's coming from. Have St Thomas 1/4 mile track booked for June 13th if you're ready by then.
Old 05-18-2018, 08:27 AM
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
maybe you have a speed limit alert set up?
Old 05-18-2018, 08:58 AM
santon997's Avatar
I checked that already. It's off. Plus it does it all over the speedometer.
Old 05-18-2018, 04:36 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Never seen/heard that before. Subscribed!
Old 05-19-2018, 06:05 AM
turbofan997's Avatar
turbofan997 is an unknown quantity at this point
Seems to be a speed warning, must be disable with a piwis tester
this function is mandatory in UAE.
Does it start always at the same speed?
Old 05-19-2018, 05:49 PM
The Bogg's Avatar
I figured it out...it's the "max boost has been exceeded" warning from your HKS boost controller. Ask me how I know, lol. It depends what you set the warning chime at. I lowered it from the default 40psi to 23psi for my 20psi test run and it triggered.
Old 05-19-2018, 08:07 PM
santon997's Avatar
Perfect. That makes sense, will check it out when I get back home from fishing for long weekend. Thanks
Old 05-22-2018, 07:22 AM
overboost warning from the EVC
#TeamAIM
Old 05-22-2018, 08:03 AM
santon997's Avatar
I need to upload screen shots of the hks. As I have the target boost set to 24 psi, warning set to 26psi. So am I actually hitting 26psi or is that pressure building up before bov's release it ( if that even makes sense, idk). Will upload some screenshots, need to get a better handle on this controller and how to use it and log data to see what boost I am actually hitting under full throttle.
Old 05-22-2018, 08:33 AM
santon997's Avatar
If you look at video it's beeping at 4000 rpm. There's no way I'm hitting 26psi at 4000 rpm. Need to upload pics of each screen of hks for you guys to peruse.
Old 05-22-2018, 12:16 PM
santon997's Avatar
HKS controller pics.
ID:	526337   Click image for larger version
ID:	526338   Click image for larger version
ID:	526339   Click image for larger version
ID:	526340   Click image for larger version
ID:	526342   Click image for larger version
ID:	526343   Click image for larger version
ID:	526344   Click image for larger version
ID:	526345   Click image for larger version
astongirl
08-17-2015 05:01 AM
carlosC4S
Bentley
09-29-2013 02:55 AM
palisades
06-03-2013 06:30 PM
SCSilvia
Cayenne 955/957
12-02-2012 05:58 PM
AeroTT
05-26-2004 11:47 PM
Quick Reply: 997.1 what is this beeping ;)
