WOT acceleration stutter/slipping
Old Jun 30, 2018 | 11:35 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
I have a 08 with roughly 30k. Over the years I've experienced a "stutter" under WOT. This only happens when I am cruising around 60-70mph in 5th or 6th gear and stomp on the accelerator. Then as boost is building, there's a stutter for 2-3 seconds. I do feel it in the pedal. It does smooth out after a bit. I've searched all the forums and only come across similar issues but with 944 and panamara vehicles.
Car runs fine otherwise. No codes no rough idle. This happened a few years back. Didn't bother me as I rarely go wot. I had a tune up at the dealer and plugs changed. It still did it. Few month ago, suffered a crack coolant pipe. As the engine was out, Indi said to change the plugs again and also changed the gas filter. He inspected the clutch and said it appeared fine. I am also good with wrenching and cleaned the two MAFs and air filter.
As the stutter/slipping is still occurring I am wondering if there are other areas which could be looked at. Thanks for any ideas
Old Jun 30, 2018 | 11:48 AM
08957's Avatar
08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute
Sounds like you have no boost leaks - coils and plugs all sorted
I would try to hook up a fuel pressure gauge and test fuel pressure to make sure it is not falling down
I would do another pressurized boost leak test also
I would not start throwing sensors at the car unless you are looking at data logs and are seeing a problem with a sensor reading
Finally - this is a long shot but I had a car years ago that exhibited a similar problem which was very hard to track down and it turned out that it was a loose plate in the battery - on the dyno the car ran fine - as soon as the car hit any G force in acceleration on the street it would miss fire - very hard to diagnose - just swapping batteries with another car solved the problem
Old Jun 30, 2018 | 11:54 AM
The Bogg's Avatar
Is it stock or has a tune? 60-70mph in 5th or 6th is fairly low rpm and it might be some knock happening on tip-in which ccould be seen in a datalog. If you have access to durametric or cobb then a datalog would be helpful especially if it's a repeatable issue.
Old Jun 30, 2018 | 12:04 PM
964hans's Avatar
964hans is infamous around these parts
That's very strange because it's a electronic throttle??
Old Jun 30, 2018 | 12:12 PM
08957's Avatar
That is very strange indeed
I would log the TPS signals you are getting when this event is occurring see if they are giving you 100% WOT
Any issues in the pedal should result in immediate limp mode
Old Jun 30, 2018 | 01:34 PM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
I see that your plugs have been changed, but have your coils? The original coils like to crack. If you haven’t updated those, they need to be, and are almost certainly your problem.
Old Jun 30, 2018 | 01:47 PM
08957's Avatar
Good catch - stupid me me I saw he was changing the plugs at the stealership twice I ASSumed he had also changed / updated the coils
If he did not update the coils then that would be a very good chance of being the problem
Old Jun 30, 2018 | 04:33 PM
Jako's Avatar
Thanks all. The coils hadn't been changed with either spark plug swap. Would the engine need to be dropped in order to replace the coils which are difficult to reach?
Old Jul 6, 2018 | 09:27 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Engine does NOT need to be dropped. Only about 2 coils are more difficult to get to. Look at my DIY, and you can see clear pics and instructions that will at least help you understand what is involved...Here is a Link
Good luck,
DC
Old Jul 7, 2018 | 07:22 PM
Jako's Avatar
Thanks Rock. Appreciate your help!
therock88
Jan 31, 2014 06:44 PM
dethman
Apr 9, 2012 01:41 PM
Cattman
Jan 12, 2010 11:49 AM
