First 1/4 mile track outing with my newly acquired 997TT.
Old Mar 30, 2019 | 06:07 AM
supra.z06's Avatar
supra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant futuresupra.z06 has a brilliant future
Decided since the weather was nice yesterday (low 60s) that I'd hit Test & Tune at Capital Raceway; car is a 2008 6MT with 42k miles, bought the car back in Jan 2018. Only mods are a 3.5" GT2 gmg racing catless but muffled exhaust, CEL is on due to catalytic converter inefficiency 🤣.
Anyways, avoided the water box on everypass, kept tire pressure at stock on my stock sized mpss tires & about a hair less then half tank on 93 octane. PSM off and sport on.
1st pass:
11.7@122mph
1.8 60ft
2nd pass (hot lapped, big nono - got the clutch hot which caused slippage)
13.0@120mph
2.4 60ft 😏
3rd pass, let the car cool down for 35 mins.
12.0@121mph, bogged at launch 🤪
2.0 60ft
4th pass, cool down for 20 mins.
11.6@122mph
1.80 60ft
5th & final pass.
11.54@123mph
1.624 60ft.
I found that this car leaves its best launching at 3000 rpm with a clutch slip. Had a great time, I haven't visited the track as a driver since 2014 (being an adult & parent has it's constraints).
Val
Old Mar 30, 2019 | 09:00 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Car is running very well for exhaust only. Now time for a flash, intercoolers, and a Sachs 2.5 when the factory clutch gives up the ghost
Old Mar 30, 2019 | 09:29 AM
supra.z06's Avatar
Thanks sir, I think I'm going to get the Sachs 2.5 and put it on the shelf as a preemptive measure. But next mod will be Cobb with custom tunes & try to get the et's into the 11.0 or lower range 🙂
Old Mar 30, 2019 | 10:13 PM
A418t81's Avatar
The factory clutch has a really weak pressure plate, relatively speaking. Once you flash the car, the clutch will be short lived...it just isn't up to the task of handling too much more than factory power. While you're installing the clutch, pony up for all the other "while you're in there" stuff as well.
Old Mar 31, 2019 | 08:43 PM
08957's Avatar
08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute08957 has a reputation beyond repute
Amen brother found this out the same way - the stock clutch sucks
Old Apr 1, 2019 | 07:32 AM
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
great MPH and 60 foot for stock. I trapped 117 (but in Florida)
Old Apr 1, 2019 | 09:42 AM
The Bogg's Avatar
1st pass:
11.7@122mph
1.8 60ft
13.0@120mph
2.4 60ft 😏
2.0 60ft
11.6@122mph
1.80 60ft
5th & final pass.
11.54@123mph
1.624 60ft.
Val
Nice job! You could use a mini-cat bung extension to get rid of the cel. It works.
Old Apr 1, 2019 | 09:45 AM
supra.z06's Avatar
On all 4 o2s? I was just going to opt to bypass them via Cobb.
Old Apr 1, 2019 | 11:00 AM
Edgemonty007's Avatar
Edgemonty007 has a spectacular aura aboutEdgemonty007 has a spectacular aura about
no, just for the last two that would be typically behind the cats.
Old Apr 1, 2019 | 11:56 AM
A418t81's Avatar
If you’re planning on flashing soon I wouldn’t worry with 02 devices. They’ll just turn motorsports flags on in the ECU and you’ll be rid of the codes. If you want to pass OBD emissions then you’ll need the hardware referenced and the motorsports flags left off since that disables the rear 02 routines.
Old Apr 1, 2019 | 01:52 PM
you can bypass them if your state emission doesnt require OBD readiness, because all it does is just shut the light off.
#TeamAIM
Old Apr 3, 2019 | 07:36 PM
Rodbuster's Avatar
Rodbuster is infamous around these parts
Good job! Please keep us posted with your updates.
Old Apr 3, 2019 | 07:37 PM
supra.z06's Avatar
Will do, next round will be Cobb ap with custom tunes, then clutch & inlet pipes. Then with the advice of prodigymb, I'll pick an intercooler. But everything will be done in stages.
Old Apr 9, 2019 | 09:32 AM
intercoolers in time for summer is definitely a good move!
#TeamAIM
Old Apr 10, 2019 | 06:41 PM
supra.z06's Avatar
Need to spend sometime and read the pm you sent me about which inlet pipes to go with. What ic's do you recomend?
I saw that ams are made in china, do88 dont run end to end....
